Results 1 to 4 of 4
Thread: 1994 K75S Replacing fan motor question
    Apr 2007
    Rockport, TX
    Question 1994 K75S Replacing fan motor question
    I'm about to install the new fan motor I got from Beemerboneyard recently.
    Wondering if I will need to undo both sides of the fairing and both sides of the radiator hoses to do this---or can it be done on one side? If so, is one side better than the other in terms of access?
    I know I will need to let the radiator fall forward a bit after loosening the radiator mount so I can then remove and remount the fan so I suspect I'll have to do both. Just in case I thought I'd inquire here beforehand.
    ---Jeff
    #13338 PGlaves's Avatar
    Count on both sides. The last time I did it I removed the radiator completely. That was on a picnic table at Hungry Mother State Park.
    Apr 2007
    Rockport, TX
    Figures. OK, Paul, now I know what I'm getting into; thanks for the info. I imagine that doing that on the road wasn't much fun, either!
    Regards, Jeff
    ---Jeff
    Quote Originally Posted by Zagando View Post
    Regards, Jeff
    It actually wasn't much different than I would have done at home. Only basic tools needed. Captured and stored the coolant in a plastic "coffee can". I bought some Heet and poured it in the gas tanks of our 2 bikes. I cut the bottom off the bottle and used it for a funnel to refill the radiator. Other than that trick it was pretty routine.
