Results 1 to 8 of 8
Thread: 2013 GTL Trailer Hitch?
    YYT-LAS
    Anyone have lead(s) on a trailer hitch for the 2013 K1600GLT and associated wiring that protects the CANBUS?
    Astatula, FL
    I would check with Bushtec. They have the wiring figured out from earlier canbus models and may have a hitch , at least in the design stage.
    Bob Weis
    '04 K12RS - Hannigan Hack
    Nov 2005
    Fairfax, VA
    Bushtec definitely does have a K16 hitch -- recently released (in the last month or two). The different versions may be found here: http://www.bushtec.com/BMW-Motorcycl...shtec-s/21.htm
    Mark Neblett
    Fairfax, VA
    #32806
    YYT-LAS
    Thanks! I will give Bushtec a shot.
    -Walt 2wheelfamily's Avatar
    Jun 2006
    Sierra Vista, Arizona
    Quote Originally Posted by 91466 View Post
    If you decide to install it yourself be sure to let me know (here or PM). I will save you a lot of time and headache. -Roy
    K1200LT Dream
    Oct 2008
    near Quebec City
    Cool Trailer Hitch
    I bought mine at DMC sidecars complete witch wire
    Nov 2005
    Fairfax, VA
    I picked up another GTL in January, and installed a Bushtec in place of the DMC hitch I had on my previous K16. For the electrical, you can also get an isolator from Bushtec, or just purchase an isolator directly from Electrical Connection.
    Mark Neblett
    Fairfax, VA
    #32806
    YYT-LAS
    Hitch Installed
    Thank you everyone for your input. I went with the DMC hitch and it was pretty easy to install. Took about 3 hours going slow. As for the wiring, all was included except I needed to buy a device that integrates the turn signal and brake lights (wires) since I use a four wire (three with ground) plug. Just got back from a trip to Grand Canyon and trailer pulls great and all electrical is fine. Thanks again!
