Results 16 to 30 of 44
Thread: Touring bike with best miles per tank?
    Mar 2012
    Las Vegas
    Quote Originally Posted by moshaffer View Post
    My 08 RT gets 50+ MPG, always..
    No offense but I call BS--really? How?
    Really??
    Quote Originally Posted by moot View Post
    Learn how to ride. No jack rabbit/jackass starts to begin with really improves your gas milage and easy acceleration. Learn how to ride and that is no BS as you seem to think.
    Mo Shaffer
    Maggie valley NC,
    St. George, BM
    K75 Preservationist k75s's Avatar
    Far East Kansas
    Miles/Tank
    Quote Originally Posted by DonTom View Post
    You cannot always find a gas station where you need one. But out in the boonies, when far from all services, the other problem usually isn't much of an issue-Don- SSF, CA
    I agree with you - I take some routes through Kansas and Colorado where the gas stations are sparse and you can not even depend on them to be open. I don't like to have to be tied to a specific route based on the spacing of the gas stations.
    I cringe every time BMW releases a new bike with less fuel capacity.
    2014 R1200 GSA (Property taxes & registration: $309), 1992 K75s (Property taxes & registration: $37)
    Registered User DonTom's Avatar
    Jan 2011
    South San Francisco, CA , Reno & Cold Springs Valley, NV
    Quote Originally Posted by stkmkt1 View Post
    I do not recommend you travel that far without a break.
    Taking breaks has nothing to do with this. Ever have to ride 20 miles out of the way to get to a gas station, but you really wanted to go the opposite direction where the next gas station is 150 miles? I usually prefer the roads away from the major freeways and there are MANY routes in the USA today that are 100's of miles between gas stations, even more sometimes if you ride at night.
    There might not be a gas station where I need it, but I can take a break every 20 minutes on the route if I want to.
    IMO, miles per tank is very important, at least to me. If you only ride from one town to the next, it usually isn't much of an issue, but even then there are a few rare exceptions.
    -Don- Reno, NV
    Original owner of:
    1971 BMW R75/5, 1984 Yamaha Venture, 2002 Suzuki DR200SE, 2013 Triumph Trophy SE, 2016 Kawasaki Versys 650 LT
    Jan 2011
    Quote Originally Posted by k75s View Post
    I remember in 73 when the smaller toaster tank came out. I was so happy I bought my BMW in 1971, when they claimed it was 6.3 gallons. But later, I discovered BMW lied, as every cycle manufacturer did back in those days about almost everything. My 71 BMW stock gas tank is 5.8 gallons, but all their books, advertisements and service & owner's manuals claim it's 6.3 gallons. It's impossible to get even 6.0 gallons in it even if bone dry. But it was still the largest tank out there back in those days.
    Prior to that, I ran out of gas several times on a Honda CL350 that I used to own. Ever since those days, gas tank size has been the very first thing I check into on a new bike.
    The only reason I bought my 84 Yamaha Venture (5.3 gallon tank) was because I got a special deal on it where I saved $2,000.00. Or else I would have bought a bike with a larger tank.
    It seems BMW now has the largest tanks out there, so I am checking into BMW's first again.
    Seems BMW has really changed since 71. Back then they were low tech compared to most other bikes and only had a few models. Now, it seems to be the opposite. But back then as well as now, they have large fuel tanks, with the exception of the toaster tank in 73 or so. I would not consider BMW in 73 for that reason alone, if I were looking for a new bike then.
    -Don- Reno, NV
    Original owner of:
    Gary98
    My brother's '06 RT consistently gets 45-47 mpg at touring, ie, 85 mph speeds. My GS, I have to be looking for a gas station at that speed at around 150 miles. He fills up every other time that I do.
    With your info., I checked the specs on the web.
    I see the R1200GS ADV has a 8.72 gallon tank and gets 38.56 MPG average or 336.25 miles per tank.
    The RT has a 7.13 Gallon tank, 39.0 average MPG, or 278 miles to a tank.
    Thanks for the info.
    -Don- SF, CA
    I routinely see 50-52 mpg, thus the 300+ (RT) and 400 (GSADV) mile range noted. Altitude helps.
    Fuse lit.... PittsDriver's Avatar
    Feb 2012
    Annapolis MD
    The GTL, according to the specs, has a half gallon larger tank than the GL. So 40 times 7=280 miles, seems like quite a reasonable range. But the more the better, but there are some other things to consider too.
    That was the case when the bike was first announced but then they went with the same tank on both models. All K1600GTs have the same tank capacity now as the GTL.
    To the folks that say that I haven't "learned to ride my bike right" because I'm getting poor gas mileage - I could say the same thing because you are. Neither would be correct though. I don't ride a motorcycle because it's an efficient way to get from one place to another. I ride because it's written in my DNA that I have to turn gasoline into fun and it's something I've been doing for nearly 4 decades. Fun to me means wearing the tires out on the edges first with tread left in the middle seeking out twisty roads and indulging in the intoxicating power of my K16 engine. Tires and gas are to be sacrificed and the greater the quantity the greater the fun.
    I would never say though that you're not riding your bike property if you're not doing that as well. There's enough room on the road for commuter bikes and dinner runs with granny on the back. Nothing wrong with that and if high mileage numbers make you smile then pump up on those hard rubber tires and set it to rain mode and enjoy!
    2012 K1600GT, Vermillion Red (for the epic road trips) (gone but not forgotten)
    2013 S1000RR, Granite Gray (for the track)
    2014 KLR 650, White/Black (for the TAT)
    2016 R1200GS Triple Black (for all of it)
    Quote Originally Posted by Gary98 View Post
    The RT slips through the air a lot easier than the GS. When you add things like flat Zega panniers to the GS as I have done it makes it even worse.
    That said, my gas mileage depends mostly on my right wrist. As I normally ride I get about 42-43 MPG. There have been times where I got 50 MPG... usually when following a friend who rides maybe 10 MPH slower than my typical pace. I've also got as low as 34 MPG fighting a head wind while running through the desert about 10 MPH higher than my usual pace.
    Apr 2009
    Huntersville N.C.
    My LT's get over 50mpg at speeds below 55mph & around 46mpg on the interstates. The tank holds about 6.2 gallons. In town I fill up at around 300 miles & on the highway at around 230 to 250 miles.
    Dave Selvig
    2004 Black LT
    2000 Canyon Red LT
  11. #26
    They aren't stupid and these days this is usually accompanied by a more economical engine than the previous model.
  12. #27
    Far East Kansas
    Fuel Capacity
    I'll take both! more capacity and more economical engine
    When I pull the plastic panels off or remove my bike's fuel tank, I know I could have designed another 0.5 to 1 gallon of fuel space.
  13. #28
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    Size Matters !
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288, Board Member, Divers Alert Network
  14. #29
    Registered User selyab's Avatar
    Sep 2009
    PNW
    GSA wins
    because it never even enters my mind that I might not make it to a gas station. I'm not riding through Mongolia but I do ride in Oregon/Washington. If you want some data, I have never reset my fuel consumption computer since new and it shows I average 45 mpg with panniers and top box. That works out to about 392 miles per 8.7 gallon fill up. I do worry that my gasohol might go bad before I can burn the whole tank though.
  15. #30
    Quote Originally Posted by selyab View Post
    Morris Kreumke never woried about running out on his custom Goldwing either. He once rode from the US border crossing at Laredo, Texas to the Canadian Customs station north of Minnesota without stopping or putting his feet down. He had 41 gallon capacity if I recall correctly. Some called it a stunt. He called it an adventure.
    The reality also is that there are vast portions of the western plains that are very unlike Washington and Oregon. It is easy to go 100 miles without encountering a gas station if riding on two-lane roads. Sundays, or nights can multiply those distances.
    Most places, you can live with the range of stock BMWs if you gas early and often. There are spots where it is likely that if you ride past an open station at 100 miles on the tank you might not make it to the next reliably open station. If you gas at Alpine, Texas and pass on Sanderson at 90 miles you will be at 215 when you hit Del Rio. That might be a problem.
