Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Not another Oil thread....really (Camguard)
    cessnadog@gmail.com
    So, I am offering up something I found and am sure that some here will tell me I am an idiot... But here goes.
    I am a private pilot and am heavily involved with the care and maintenance of my airplane. To understand, generally folks plan on replacing airplane engines every 2000 to 2500 hours. At a cost of about $40,000. So every hour you fly you assume you have "consumed" about $20 worth of your engine. Anything we can go to get more hours out of them is a good thing.
    In addition to routine maintenance, flying frequently has a major positive impact on engine life. Worst thing you can do for an aircraft (think air cooled, horizontally opposed, sound familiar?) engine is to park it for the entire winter.
    Over the last few years a new product has emerged as helping with this issue of corrosion during times where there are significant delays between running. It was in fact designed exactly for this purpose. As a side benefit it also has wear reduction qualities in addition to anti corrosion.
    This product is called Camguard, made by ASL. There are separate Aviation and Automotive (including motorcycle) versions.
    Many aviation folks much smarter than me (google Mike Busch and Camguard) have done their own evaluations re Camguard and corrosion prevention. My experience is limited and yet for me pretty compelling. We do oil analysis as a routine part of the maintenance of the plane. The very first time we added Camguard to the oil, the lab noticed the reduction in the "Wear Metals" in the oil I believe the quote was "This engine is flat out wearing less"
    I just got my R1200GSA, and almost immediately did an oil change and will be doing oil analysis. The sample I just sent off did not have Camguard in it and in fact I don't even know how many miles were on it, (other than the guy I bought i from said it was time). I will report back after my next change difference or not.
    A Pint of Camguard will cost you about $25. You only need about a cup in the oil of an R1200.
    I don't sell Camguard, I don't own part of Camguard or the manufacturer. I don't work for, or really even know anyone that falls into either of those categories... just my .02
    Discuss.
    Note that BMW says don't switch to synthetic oil for x thousand miles, ostensibly to assist break in. Maybe delay using your stuff, too.
    Diamondhead, MS
    Good point. Rings might never seat.
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Note that BMW used to say don't switch to synthetic oil for x thousand miles, ostensibly to assist break in. But they don't say that in the current version of the Riders Manual.
    Fixed.
    Wilmington, NC
    I suppose the first question would be why?
    An added $25 every 6K miles for what? These motors already run more miles than most folks will ever keep a bike so even if you doubled that, what's the point? Most will have long since wanted another bike by then..
    Maybe if you do 50K a year?
    Diamondhead, MS
    I've always wondered about that, too. Look at all the low mile bikes for sale out there. Most people just don't keep bikes long enough for this kind of stuff to matter. Even a lot of people who do keep them don't really put many miles on them.
    cessnadog@gmail.com
    Why?
    That is a really an interesting point. I would actually make the opposite argument. If you put 50k on a year you may not need it. If you ride every week you may not see any real benefit. If you park it all winter (I live in Minnesota) and want to minimize potential corrosion from sitting all winter you might see the benefit.
    Half a bottle ($12.50) every 6000 miles is a trivial amount compared to what I am spending on the bike.
    RAINEY 187132's Avatar
    Sep 2012
    Grand Rapids, MI
    Use a high quality oil like Mobil 1, Valvoline Racing or even the BMW OEM oil and your are fine. Using a high quality oil preferable a Group IV (PAO) base stock keeps the acid and oxidation at bay so there should not be a problem. If you're using a quality oil adding something to it waste money and can actually degrade the overall quality of the oil.
    Also remember when doing oil analysis that when an engine is new and going through break in you will see higher "wear Metals" which will slowly be reduced over time. Adding the additive that you speak of may not have truly reduced the wear metals because they may be lower for that change.
    We all like another oil thread
    Jason
    Grand rapids, MI
    2012 BMW R1200RT
    Diamondhead, MS
    Quote Originally Posted by Cessnadog@gmail.com View Post
    So its an anti-corrosive ?
    cessnadog@gmail.com
    What it it?
    It has anti wear goodies in it but original and main purpose for use is to prevent corrosion. I would not use it in a car unless that car was sitting long periods of time between starts.
    An airplane engine is good for about 2000 operating hours or about 12 years. If you don't put enough hours on it to get to 2000 hours in 12 years we start to worry about what is going on inside the engine, and most pilots will assume that you will never got to those 2000 hours. Airplanes are worse than motorcycles in that they may only fly a few day each month.
    Let an engine sit for weeks and it will build moisture inside from changing temperatures and humidity.
    SW Ohio
    Seems like a fix for something that ain't broke, at least on motorcycles. I'd worry more about old gas and changing the brake fluid after long term storage.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Aug 2012
    Darn, I thought this was going to be another oil thread.
    Lynn
    MOA #57883
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288
    atlanta
    Cessnadog, I assume you mean major overhaul rather than new engine.
    Marty Hill
    12 GS black/Boxer Cup Replika
    ride till you can't
    cessnadog@gmail.com
    Yes, I mean major overhaul... In my mind it results in a new engine. One of the common means to this is to actually trade the core in for a factory rebuilt engine.
    they measure all of the reusable parts to make sure they are within limits. You generally get new pistons, cylinders and bearings. Block, crank and cams gets a trip to the machine shop for an inspection and clean up. In the end, if done right, there really is very little difference vs a brand new factory engine.
