Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: 2004 1150 rt abs
    May 2007
    Windsor , Co.
    2004 1150 rt abs
    I am considering a 2004 1150 RT.
    I do not care for the servo assist on these models but really like the bikes otherwise
    My question is has anyone tried to replace this unit with a later model without the servo,or removed it and gone the non ABS way.
    If so how did it work out?
    Thanks for your comments in advance
    Dave
    Jammess jammess's Avatar
    Aug 2005
    Florence, OR.
    Hello Dave,
    Yes, I totally removed the ABS system on my '04RT couple years ago and would do it again in a minute. Now I have very powerful and predictable brakes and I especially don't miss the linked brake feature. I wish the '04 R1150 would have had ABS as an option. That said I also have a pristine '94 R1100RSL with a very fine ABS system and I have no plans to remove or otherwise modify this system. Typical BMW, they just had to re-invent the wheel on the 1150's rather than stay with what worked. The police departments wanted nothing to do with the ABS system as it appeared on the 1150's, can't blame them.
    Jammess
    Quote Originally Posted by Red100RT View Post
    Now there's revisionist history!
    Way I heard it was ABS was a California requirment and was what put BMW in the Authorities bike business in the USA and most other jurisdictions just copied the CA requirements.
    Aug 2005
    Florence, OR.
    Hello Kent,
    I don't know could be law enforcement folks wanted ABS but the servo assist linked brakes version failed to impress. The ABS version as it appeared on the 1100's and later 1200's is, imo and others, much easier to live with than the afore mentioned un-popular fiasco system common to the 1150's.
    I remember the day I took delivery of my R1150RT. The dealer politely suggested I use his parking lot to familiarize myself with the bike before going down the road. He should have phrased it: Going down ON the road. I declined stating that I am a long term and quite capable road warrior, no problem. Well, at the first stop light controlled intersection I very nearly put her on her side. Then, within the first two months of ownership, I bought two rear view mirrors and a paint touch-up kit all because of those GD linked brakes. If I didn't have a very comfortable Russell saddle and if I hadn't succeeded in transforming the beast into the smoothest running motorcycle I have ever owned, without ABS, I would sell it and keep my pristine nearly new '94 R1100RSL with ABS brakes that work when you need them and stay in the back ground when you don't.
    Does this qualify as a rant?
    Jammess
    Diamondhead, MS
    Exactly which years had that brake system ?
    ONE LESS HARLEY 04r1150rs's Avatar
    Jul 2005
    Bowling Green,KY
    so there were no problems using the stock front and rear master cylinders to get good braking on par with your R1100?? what about the brake lights I've heard thet the R1150 has that wired differently. Did you just unplug the lights which would flash showing the ABS is faulting???
    More info on removing the system.
    Richard
    2004 R1150RS
    1984 R80 G/S
    2003 Suzuki DRZ 400S
    May 2007
    Windsor , Co.
    Quote Originally Posted by Acejones View Post
    I think It started in 2002 and went into 2005 on some models but for the most part stopped at 2004
    Dave
    Aug 2005
    Florence, OR.
    Quote Originally Posted by 04R1150RS View Post
    OK, the front and rear master cylinders provide all the braking power you could ever want. The way I handled the brake lights was to use a Darlington transistor as a switch to light the brake light with the front and rear brake micro-switches connected in series so that if either one or both opened the darlington went into conduction with the brake light as the load. another simpler way would be to just use a relay connected so that when you turn on the ignition switch the relay energizes with ground applied through the two micro-switches again connected in series. Then, if one or both switches interrupts the ground side of the relay coil a relay contact would close applying ground to the tail lamp. You would use a normally closed relay contact. You also need to buy a longer brake line to connect the rear brake to the rear master cylinder and a connection bracket assembly to allow both front brakes to be connected to the front master cylinder. This connector assembly is a BMW part. if you wish to proceed I can give you part numbers for the brake line and the connector. When I converted my brakes I removed all traces of the ABS system and sold the modulator on the MOA Flea Market for 500 bucks. Also, I could tell my bike had shed some top heavy weight without the modulator which is fairly heavy at around 20 pounds if memory serves so for me it was well worth it and I haven't missed the ABS system not once and when I bleed and flush my brakes now I'm done in 30 minutes. As far as a comparison to my 1100 goes the 1150 brakes are every bit as powerful but with no ABS like the 1100 still has. Oh, bleeding and flushing the ABS system on my 1150 is every bit as simple as the 1100 is with its earlier ABS system.
    Remove the ABS relay from the fuse relay box under the seat and no more ABS lamp flashing or otherwise.
    It really still irritates me that I paid good money for the lousy ABS system used on the 1150 bikes. Thanks for nothing BMW and just see if I ever in my life buy another one of your lousy bikes new! Not freeking likely! Oh, I hear that if BMW bikes fire you up you should avoid their cars like the plague which they are!
    Wow, this does qualify as a rant.
    Jammess
    Bill Lumberg 175781's Avatar
    Dec 2011
    ABS is one of the reasons I still have my 04 R1150RT-P. Too many close calls with bad drivers pulling in front of me or being stopped in the road around a curve or over a rise with other bikes. While I got used to it quickly, I wouldn't mind losing the servo part. Neither the servo nor the linked brakes have ever caused me to lay the bike down. The abs has kept me from going down a few times on wet leaves and concrete.
    R75/6, 2004 R1150RTA.
    maacova maacova's Avatar
    Richmond, VA
    04 1150 RT Brakes
    Have to tell you I love my "Whizzy" ABS brakes on my bike. Took a little getting used to but I have nothing but good things to say about them. May be the best brakes on any vehicle I have ever owned. I was worried about the bleeding of the system but even that was not bad when I got into it.
    Ken Denton
    Maryland
    I like the ABS on my 04 RT also. I'll never buy a bike without ABS if I can help it.
    2004 R1150RT 151,500 miles , 1991 K100LT 128,000 miles, 1982 R100RT 106,900 miles
    Total 386,400 BMW miles
    AMA,BMWRA,BMWMOA
    Aug 2005
    Florence, OR.
    Quote Originally Posted by kioolt View Post
    Well then, I guess you will never experience the joys of riding and owning an airhead.
    Jammess
    South Carolina
    I've owned three bikes with ABS, and I never really cared for it. My R100RT and my Harley don't have ABS, but my new 2012 GS does. What I like about the GS is you can turn the ABS off. Its always been my opinion that ABS gives a rider a false sense of security.
    AKA SNAPGADGET
    Maryland
    If you would read my signature you will see that I do own an airhead. I said I will never buy a bike without ABS. When I bought the airhead, ABS wasn't even thought of on cars. My 82 R100RT does have ABS on the rear brake. No matter how hard you step on it it won't lock up.
    AMA,BMWRA,BMWMOA
    Nov 2007
    I love ABS and will not have a bike without it. There are now leaves on the roads, and sure enough someone barreled out a driveway very fast without a look last year bout this time. There were lots of leaves and I was able to break hard and steer some without worry.
    There were some getting used to it problems, the best tip I can give is never use more than one finger below 15 mph or when parking. (or people watching.
    Next tip is turn off the bike with the key at about 15 mph in a safe place and feel how the bike feels without the servo. Do this enough times you develop some muscle memory. Refresh your skills from time to time. I have done this from 60 MPH and you can still stop very fast, just takes a mighty squeeze. You 04 will have the less sensitive type.
    Rod
