Is it necessary to ground the plugs and turn the engine over several times before starting after an oil change. The fellow that told me this said if you have an oil cooler you should open the the thermostate with a sp bolt befor turning it over. I have heard about draining the oil from the thermostat with an oil change. Is turning the engine over several time necessary?
Ocala Fl
