Results 1 to 5 of 5
Thread: 2001 K1200RS Final Drive Spline Lube
    Kawa Afterthought weschmann's Avatar
    May 2012
    DeSoto MO
    Looking for a link to information that will provide a guide to dismantling the final drive spline assembly from the transmission back, with the intention of lubricating the spline... I am experiencing some difficulty downshifting after coming to a stop if I forget to downshift to first before stopping. I have to work through some shenanigans with rocking the bike, or letting out the clutch just a bit to get the gears to change....I've looked for a YouTube link but not had much luck with finding anything on the K bike.... Is there a CD for this bike that would provide some direction? I like the challenge of wrenching myself on the bike, but an not necessarily an accomplished MC mechanic....
    Jun 2007
    The best thing would be a combination of either the hard copy BMW shop manual or the CD, available from any of the on-line parts departments for the BMW dealers - Bob's, Chicago, A&S, etc. THEN, have a Clymers as well. This will give you the step by step. Although, by your description, I doubt it is the final drive. I is more likely inside the transmission. Problems with the final drive will more likely have different symptoms. This type of issue has been dealt with before here and there are other posts you might search for that deal with the symptoms and solutions to this type of problem, shift dogs/forks? something like that? Maybe one of the true mechanics will chime in.
    Jim Douglas '00 K1200RS >137,000 miles -- owned since new,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    The final drive spline is unlikely to have an affect on shifting: the clutch hub spline will.
    May 2012
    DeSoto MO
    PGlaves, thanks for the clarification.... I'll start looking at information on the clutch hub spline, as I believe that is what I found in a previous thread which talked about my shifting problems... I just didn't state it very well..... I would assume to get to the clutch hub spline, I would have to start with disassemble at the final drive spline and then work forwards on the bike...
    Dec 2004
    Winnebago, Il
    Yes, you would have to remove the transmission to lube the clutch splines which means everything behind the tranny must move out of the way.
    If like the 1200 LT you will also need some special tools to install the swing arm.
    Roy
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
