Results 1 to 12 of 12
Thread: What No DIY/Tech Data for Alt. Belt R&R 2008 RT?
    Jeff cookie's Avatar
    Jun 2008
    Paradise, CA
    I am so impressed and continue to pay my annual dues to this great club. One of the attractions besides this great forum is the tech. help. I am surprised though, there is no alternator belt replacement procedure in the do it yourself section.
    Is there a gasket or sealer for the cover?
    Are there any tricks?
    Am I missing something?
    Jeff Anderson
    I ride a 2008 R1200RT
    Jun 2008
    Paradise, CA
    Quote Originally Posted by drgnhtr View Post
    After reviewing this fellows experience I may just hire the experts at the Dealership to do it.
    Thanks!
    Jeff Anderson
    Nov 2011
    Central Ohio
    Google "replace R1200 alternator belt"
    There are plenty of links, most make this look like a pretty straightforward job.
    Like this video: http://www.youtube.com/watch?v=YzPTPN98x40
    Larry
    2006 R1200RT
    Sep 2008
    Wilmington, NC
    The current R1200 belt is a stretch belt- you literally stretch it on and off and the only wrench needed is one to turn the pulley after the cover is removed. BMW makes a pricey but cute little tool to assist that is a favorite of some but a bit of plastic sliced from an old plastic bottle works as well.
    FWIW, the factory recommended change interval is quite conservative. Belts changed that early typically look almost new and still have good stretch capability, not being worn, cracked or over stretched. Breakage is not common. Some folks carry the older one as a spare but I've yet to meet anyone who told me they got to use it...
    If you've never changed a stretch belt you may find it a bit of a nuisance initially compared to older stuff with tensioners to adjust but it is simple and easy once you "get it". If you pay a dealer, the cost should be modest, no more than 30 min of shop time. The belt was $27 last time I bought one, maybe a couple $ more now..You can pinch a finger if you're sloppy doing it so watch where you put them.
    Your 08 RT doesn't have the foam talked about in that GS posting- there is nothing under the cover to remove. Also, use a correct socket with extension to turn the pulley if you don't use the BMW tool- that way you don't need an assistant to turn the rear wheel...
    Spring Lake NJ, USA
    Quote Originally Posted by cookie View Post
    Glad that you find the DIY's useful (since I had a bit to do with them existing..) but no one is paid to do one, and due to the litigious nature of our society, we have rather strict rules/format used to do them. We also are limited to one photo per posting, which adds a bit to the chore of writing them.
    So - no one got around to the alternator belt.. but if you'd like to contribute one, I can get you access to a secret development subforum where it can be worked on, and when it's complete it gets moved over to the DIY public forum. At least I could have done that - but since some parts of the forum aren't working since the virus attack, it may or may not be a good time to do it.
    Ping me off-line if you're interested. I have a step-by-step writeup on writing a DIY in the format we use.. be glad to direct you to it.
    Jun 2008
    Paradise, CA
    Thumbs up Wow That Is Easy
    Quote Originally Posted by lkraus View Post
    I just watched this video. Now that is an easy job!
    I found the suggested mileage for replacement is 36K, since I am at 24K I will wait a bit and do it myself.
    Thank you for this information !
    Jeff Anderson
    Jul 2007
    THE BIG SKY
    Talking
    I'm doing a major service on my R1200R. Putting the belt on is the easy part. Removing and replacing the crash bars, auxilliary lights and the oil cooler is the tedious part.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Jul 2007
    THE BIG SKY
    By the way, this technique does not work on a R1200...
    http://youtu.be/BQhfcdQf1QA
    Kevin Huddy
    Mar 2008
    Camas Valley Oregon
    Quote Originally Posted by AKBeemer View Post
    Kevin why remove the oil cooler? Did you leave your beer in it?
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
    Jul 2007
    THE BIG SKY
    Quote Originally Posted by MPMARTY View Post
    On the R it seemed the only way to get to the front engine cover. No beer was spilled in any case.
    To get to the alternator belt one needs to remove the front engine cover. Two of the fasteners that hold the cover on to the engine are behind the oil cooler. Once I had the cooler loosened I decided to remove it to determine how much oil was remaining in there. It also appeared to be that trying to replace the belt with the cooler just leaned forward might be more trouble than it's worth. Probably added 10 minutes to the job by completely pulling it off the bike. For the more anal amongst us, pulling and draining the cooler will mean the oil in the bike is just a bit cleaner and it is easier to access places on the engine for cleaning. While I admit to sometimes going overboard in such matters, I will not be pulling the cooler for every oil change. By the way, after sitting for 24 hours with the drain plug and oil filter removed there was still 6-8 ounces of oil hiding in the cooler.
    Kevin Huddy
    Sep 2009
    Chestnut Hill, MA
    BMW Belt Replacement Recc. Now 24000 miles
    I was passing through San Jose, CA on a trip during 9/2012 and had SJ BMW do my 24,000-mile Service. They told me that BMW had changed the alt-belt replacement interval to 24,000 miles, down from 36,000 miles.
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
