Results 1 to 7 of 7
Thread: 2012 RT-What is this connector for?
    Registered User wvpc's Avatar
    Dec 2009
    Ypsilanti, Michigan
    Hi all,
    I thought I had saved a copy of my wiring diagram but can't seem to find it at the moment. Can someone tell why this connector up by the steering head is present and what it's purpose is? Normally it is capped.
    The reason I ask is I am installing some Photon Blasters and need to find some way to tap into the brake light.
    12 R1200 RT
    83 R100 RT
    MOA #148075, BMWRO Shaun09's Avatar
    Mar 2009
    Eugene, OR
    Have you tried looking at www.realoem.com or Max BMW's parts fiche? Looking there might suggest a radio connection, but I'm not sure. Doubtful that you'll find a brake light feed up there.
    Chris
    2009 BMW R1200RT (Shaun), 2004 MINI Cooper S (Gromit), 2006 BMW X3 (Wallace)
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    Could that be the plug for the "factory" GPS?
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
    Nov 2011
    Central Ohio
    Photon Blasters usually are on the front of the bike and are always on. Mine are tapped into the parking light (blue/light blue) wire at the headlight connector. There is also a ground (brown) wire available at that connector.
    The Skene P3 brake lights can tap into the alarm wiring for power - there are photos of this on the Skene web site.
    Larry
    2006 R1200RT
    Dec 2009
    Ypsilanti, Michigan
    Thanks for the help. It must be the radio feed as it much bigger than the gps harness. No radio= no connection. Doh!
    12 R1200 RT
    83 R100 RT
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Quote Originally Posted by sedanman View Post
    The factory GPS plug is a small squarish three pronged plug under the front shock.
    Dave
    Tame Racing Driver Stig's Avatar
    Dec 2009
    Hudson Valley, NY
    Tapping the parking light bulb is probably the easiest way to do it and shouldn't throw a fault with the CAN BUS. If your hands are smallish you should be able to do the whole install without removing any of the bodywork.
    Craig
    New York's Hudson Valley Region
    2009 R1200RT
    MOA #146131 IBA #55715
