Results 1 to 15 of 17
Thread: 2011 RT With No Problem?
    Frank Ferrante
    Toms River, NJ
    I sit and read posting from riders with the same problems. Oil consumption, bluetooth radio issues, bike won't start, etc. My RT doesn't burn oil, my Sena paired with no problem and it starts every time. The only problem I have is that I have a Garmin Zumo 450 and I don't hear turn by turn directions. And that is because I don't see any reason to invest in a new Garmin. Are there any other trouble free RT's out there?
    Frank Ferrante
    2011 BMW R1200RT
    2011 Triumph Bonneville T100
    Nov 2006
    Yes, my 2011 has been trouble free (except it won't start on cold mornings, 30's, after being left outside in 20 degree temps). Just rode it 7000 miles across the country and back and it was flawless, except for the cold temp starting. BTW the battery has been checked twice and shows no problem. May be just cold oil and a tight new engine.
    Larry
    May 2010
    Thumbs up
    Just when I was about to start a thread with ?┬ŻNo problem?? as the main topic. Thank you.
    2012 RT with 13,000 kms, no problem, beside one faulty battery and one flaky paint brake liquid reservoir cover. Both replaced under warranty. That's all. So far.
    May 2010
    Quote Originally Posted by royaltyl View Post
    Larry
    Do you pull in the clutch when starting the engine? It might help.
    Nov 2006
    I do. And it has had 10W-50 and 10W-40 oil in it, when it wouldn't start.
    Registered User LCampbell's Avatar
    Nov 2006
    Vacaville Ca.
    Mine has been trouble free since the rear shock & the ABS computer have been replaced
    2011 R1200RT, 75 R90S, 70 R75 Race, Vintage Kneeler sidecar R75 powered
    Jun 2009
    10,000 miles on my '09 and 1 Fuel Strip.
    Flawless otherwise!
    drgnhtr
    Jun 2008
    Castro Valley Ca.
    I'll play
    08, 17,000, one fuel strip at the 600 mile mark.
    Of course I just retired so I probably just jinxed myself.
    Mike LngRdr's Avatar
    Apr 2012
    Moore, Ok
    problems
    2012 RT approaching 23K and no issues at all. Just got off of it after a nice ride today.
    IBA Number 49673
    Moore OK
    http://lngrdr.blogspot.com/
    Feb 2012
    Stanwood, WA
    Problem Free 2011 R1200RT
    Quote Originally Posted by ff73148 View Post
    Like you, my 2011RT has been absolutely trouble free. It doesn't burn any oil, hasn't missed a beat, ESA II works perfectly, and my BMW GPS syncs just fine with my Schuberth C3 helmet. I love it!
    Registered User RT290's Avatar
    Mar 2012
    Sheboygan, WI
    My 2011 burned a little oil but abruptly stopped at 12,000 miles when the fuel float stopped working. It's a machine. Things break sometimes.
    Joel
    Feb 2012
    Interesting to me how won't start below a certain temperature and only a new shock and computer is viewed as trouble free on bikes which have barely even been ridden. I think the failure rate on these motorcycles (including mine just returned from the 2nd tow in for major failure) atrocious. I would love to see some real data on failures. The reliability is not there any more. Glad to hear someone is having luck but frankly it's luck to not have a late model RT having major issues. Then there are the folks who don't ride and think their bike is reliable. My bike would be great if I brought it home, put it under the cover and let it sit. Never been more disappointed in any purchase I have ever made.
    Registered User zenduddhist's Avatar
    Mar 2012
    9,000 miles and absolutley no problems. Burned a little oil in the beginning, but since about 5,000 miles oil has been stable.
    1969 Triumph Bonneville T120R, 1972 Commando 750, 1974 Vespa Rally 200, 1974 Commando 850, 1975 Commando 850, 2010 Triumph T100 w/sidecar, 2011 BMW R1200RT, 2013 Honda CB1100
    Jan 2011
    I bought my 2011 R1200RT 1/17/12. So far, I have put 19,000 miles on it and the only problem that I have had was a loose cam chain tensioner which showed itself in the form of a small oil leak.
    I sold my 2005 R1200RT with around 110k miles on it. Only problem that it ever had during those miles was a bad fuel strip (once).
    '11 R1200RT '12 F800GS BlackDenis's Avatar
    Aug 2011
    Victoria, BC
    2011 RT purchased August 5, 2011. 32,000 km on it with a emergency flasher switch failure only.
    Degeneracy can be fun but it's hard to keep up as a serious lifetime occupation. R. M. Persig
