Results 1 to 4 of 4
Thread: 6V v 12V coils on an old airhead
    Registered User AUSSIE_BMW_PAUL's Avatar
    Jul 2003
    Hi has anybody change from the original type 6v Bosch Coils used on air heads to 12v versions of the same type. You know the old style ones we used to see on cars everywhere. Ive just swapped an old 6v coil for a 12 v one that I had spare. My 90 started right up. Any feed back
    Could some nice airhead owner take a really good close up shot of the wires attached to on the ignition in the headlight.
    I need to check where all the wires go. The wiring diagrams I have I really are not clear enough.
    Any one have a ignition switch with a matching knob key for sale by any chance Cheers Paul Australia
    Fenwick, Ontario Canada
    Hi Paul
    1 switch for sale on fleabay $45 no key.
    http://www.ebay.com/itm/BMW-Ignition...9aa502&vxp=mtr
    Knights of the Roundel #333
    P Monk
    May 2005
    Port Neches, Texas
    my 1974 r90 wired like this
    g grey
    r red
    e blank
    e yello / white
    n
    align switch with the single post in vertical position to the rear of the headlight bucket and plug on the green wire. Moving to the four posts that are aligned horizontally top to bottom---- grey, red, not used, yellow/wht on bottom.
    Just happened to have my headlight out to replace lens and flasher.
    P. Monk
    74 R90/6 (also know by bride as the Black Hole). 09 R1200 GS. My wife, 1953 model who has survived aplastic anemia and a bone marrow transplant.
    If you switch to 12V coils you should add resistors to reduce voltage to 6V--just like everywhere else in the automotive world. You'll be going through points pretty fast if you don't.
