View Poll Results: Have you had at least ONE fuel strip fail?
Voters
675. You may not vote on this poll
  • YES - 2005 model year
    38 5.63%
  • YES - 2006 model year
    26 3.85%
  • YES - 2007 model year
    78 11.56%
  • YES - 2008 model year
    92 13.63%
  • YES - 2009 model year
    132 19.56%
  • YES - 2010 model year
    47 6.96%
  • YES - 2011 model year (R1200R only I think..)
    21 3.11%
  • YES - Multiple fuel strip failures - please note model/year in a comment
    55 8.15%
  • NO - fuel strip failure. Please note year/model in a comment
    229 33.93%
Multiple Choice Poll.
Page 20 of 30 FirstFirst ... 10 18 19 20 21 22 ... LastLast
Results 286 to 300 of 439
Thread: Fuel strip poll
  1. #286
    Mar 2009
    So. NH
    also knock wood 2008 RT
    2008 RT, no esa, 58,757 lucky mi. No fuel problems .
    '08 R1200RT Blu
    MOA 148050
    IBA, AMA
  2. #287
    Registered User Guardrailbob's Avatar
    Dec 2003
    Milw. Wi.
    07
    07 RT 50,000 no failure
    Bob
  3. #288
    Mar 2008
    Camas Valley Oregon
    Quote Originally Posted by Guardrailbob View Post
    http://consumeraffairs.us1.list-mana...4&e=94c41f078e
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
  4. #289
    GM Recall - Bad Fuel Gauges - Dangerous they say! BMW ?????????
  5. #290
    Spring Lake NJ, USA
    Actually - BMW has been forced into recalls for faulty fuel level gauges - on the cars. The Z3 from around 1999-2002 had problems with sulphur in the fuel building up a coating on the sender unit. They would replace it under warranty - but out of warranty, it was the owner's problem (usual BMW excuse #1 "Doesn't happen in Europe. It's your fuel..") Finally NHTSA forced them to do a recall - pointing out that running out of fuel on a highway could result in a dangerous situation and possible accident.
    I rather suspect the reason none has been forthcoming for the bikes is:
    1 - Canada hasn't called for a recall yet, so they haven't been embarrassed into it
    2 - The number of reports of the failure - despite some rather specific instructions here and in other BMW websites - is still low. Someone did a search on it recently and could only turn up 31 reported incidents. For it to have enough weight to get NHTSA's attention requires everyone who has reported a failure here to go report it to the NHTSA following EXACTLY the instructions given above. It's important to follow those instructions since if you don't - chances are - the reports will end up in different spots and won't group together when NHTSA finally gets to looking at them.
  6. #291
    Spring Lake NJ, USA
    Quote Originally Posted by espressoforyou View Post
    Of course no one should suggest that the MOA should take a proactive stance concerning yours and the thousands of other failed fuel strips. Just smile and hope that yours does not go bad after the warranty is up and thank BMW for admitting they have a problem with the fuel strips.
    While I can't speak for the MOA - I did try to take a proactive stance by posting this poll and giving instructions on how to report the failure.
    Exactly what might you expect the MOA to do? They have no "clout" with BMW-Motorrad, nor with the NHTSA. BMW-Motorrad is in business to sell bikes, as long as they are selling well - something like this falls into the noise. The NHTSA is tasked with protecting the public against potentially dangerous vehicle problems - but apparently a few fatalities are really required to get their attention.
    Question - if you had a failure did YOU report it to NHTSA? The MOA can't do that for you..
  7. #292
    Glad you started the poll Don
    Maybe a few people will take the time to report to the NHTSA
  8. #293
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    It is not a safety thing. I don't know if you can report it, like the fuel pump thing. I had one of those too, and had fuel all over me.
    That's not safe.
    My bike shown here
    Jordan M, MOA #24434
    My Blog
  9. #294
    Spring Lake NJ, USA
    Quote Originally Posted by AZ-J View Post
    That's not safe.
    Jordan,
    Having recently been in Scottsdale.. even there, running out of fuel in the middle of an interstate presents a safety hazard IMHO. That was also the opinion of NHTSA in the case of Harley's doing the same thing, and multiple 4 wheeled motor vehicles.
    It CAN be reported. The instructions are in this thread. It takes about 5 minutes. It's worth doing, rather than just complaining to the choir here. We know there is a problem, the goal is to convince NHTSA there is and get them to make BMW fix it.
  10. #295
    Fuel Strip
    Purchased a New 2009 R1200RT June 09. Fuel strip failed in the first 1000 miles. Had it replaced . New fuel strip failed almost immediately. Had it replaced around 3000 miles. Service manager at Daytona BMW suggested adding Sea Foam to cut the varnish every 3 rd or so tank of fuel. Now at 31K no problems since adding Sea Foam as suggested. Bid problem I am 162 miles away from the Dealer think BMW cares.
  11. #296
    Spring Lake NJ, USA
    Quote Originally Posted by 05biggray View Post
    I rather suspect the Sea Foam isn't doing anything much - good or bad. What "varnish"? I've never seen varnish buildup on any of the 8 strips my bike has had - they look brand new when they come out. If you go through the thread - it seems to be the "luck of the draw" if you get a long lasting replacement strip. You were likely lucky.
    BTW - please follow the directions given in this thread to report your failures to NHTSA. Its the right thing to do..
  12. #297
    Spring Lake NJ, USA
    That's not safe.
    If it's considered unsafe for an automobile to run out of fuel due to a defective fuel level indicator - I'd posit that it is even more unsafe to have the same thing happen on a motorcycle. And apparently NHTSA does agree since they've forced other bike manufacturers to fix their broken fuel level indicators.
    It will ONLY happen if you report it. The directions on doing so are in this thread and quite specific. It takes 5 minutes. It has the potential to help fellow BMW riders. Why not just do it..
  13. #298
    Spring Lake NJ, USA
    How to report fuel strip failure
    See: http://forums.bmwmoa.org/showthread....l=1#post858929 - handy dandy posting with numbered instructions on how to report failures to the NHTSA so they'll add up..
  14. #299
    Urbana, IL
    Another strip failed...
    OK. Thanks for the guidelines. We just had the 7th fuel strip fail on an '08 R1200GS. I may have said 7 before, but this time I made the NHTSA complaint and was carful to recall each strip that failed and we're at 7.
    My other bike is a BMW.
  15. #300
    Spring Lake NJ, USA
    Quote Originally Posted by cjack View Post
    Jack - you're unfortunately catching up with me.. I'm on #8 (but one never made it out of the shop..) So far - knocking on oak-grain-formica - still good. According to the service manager at my dealership the ones they've installed since about May of last year seem to be lasting. That was after BMW did the parts recall for the strips dealers had in stock, so maybe - something has changed.
