View Poll Results: Have you had at least ONE fuel strip fail?
Voters
670. You may not vote on this poll
  • YES - 2005 model year
    38 5.67%
  • YES - 2006 model year
    26 3.88%
  • YES - 2007 model year
    77 11.49%
  • YES - 2008 model year
    92 13.73%
  • YES - 2009 model year
    130 19.40%
  • YES - 2010 model year
    47 7.01%
  • YES - 2011 model year (R1200R only I think..)
    21 3.13%
  • YES - Multiple fuel strip failures - please note model/year in a comment
    54 8.06%
  • NO - fuel strip failure. Please note year/model in a comment
    228 34.03%
Multiple Choice Poll.
Page 3 of 29 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 31 to 45 of 430
Thread: Fuel strip poll
  1. #31
    Quiet One
    Feb 2010
    Jacksonville,IL
    2012 R1200R mine quit at 1800 miles, fixed at dealer . I always rely on trip meter old habit I suspect.
    Andy
    2013 R1200GSW
    BMWMOA # 155500
    1st John 4: 7,8
  2. #32
    Aug 2012
    Cincinnati, OH
    2006 rt
    23,000 miles. Still on original fuel strip.
  3. #33
    An interesting pattern is starting to emerge. I put this poll up because I can't recall anyone complaining about a fuel strip failure on '05 and '06 bikes.
    So far - with probably about 20 failures reported, there are no failures reported on the '05 and '06 bikes. If this continues and is not a fluke, a comparison to the number of hexheads BMW sold over the different years would be in order, but my initial thought is - something went downhill in the fuel strip manufacturing process around 2007, and it never got any better. Plus - this eliminates the fuel being the problem since all the hexheads are likely to be using about the same fuel supplies, no matter what year they were manufactured.
    I'll be watching the results with great interest.
    Don
    I am with you on this point, having done a great deal of research on this subject I came up with the same result.
    What happened after 2006 and what is different with the strips in 05 &06??
    My 2005 1200GS had no issue with the fuel strip sold it at 28,000 miles and 3 years.
    Dave
  4. #34
    '05 and '06 bikes without the onboard computer option came with a float. At least the GS came with a float. Perhaps the OBC option wasn't common in those years?
    The complaint from owners with those bikes is more likely to be "my fuel tank reads full until 1/2 tank is gone". When you explain how the sucking jet pump moves gas from one lobe of the fuel tank to another without the need for crossover lines that complaint sometimes goes away.
    Marc,
    Dunno, so I went to RealOEM to find out:
    '04 R1200ST - they only show a fuel strip: http://www.realoem.com/bmw/showparts...98&hg=16&fg=14
    '05 R1200S - they show both: http://www.realoem.com/bmw/showparts...99&hg=16&fg=14
    '04 R1200RT - they show only the fuel strip: http://www.realoem.com/bmw/showparts...99&hg=16&fg=14
    '06 R1200RT - same thing, only the fuel strip: http://www.realoem.com/bmw/showparts...98&hg=16&fg=14
    '03 R1200GS - same thing, only a fuel strip: http://www.realoem.com/bmw/showparts...98&hg=16&fg=14
    Same on the 06/'06 GS, and the 06/'06 GSA.
    '04 HP2 - used a float, different from the one on the S.. http://www.realoem.com/bmw/showparts...97&hg=16&fg=14
    Only one I found (and I didn't look at every one) was the S that used the float assembly or the strip. That's probably a rather small sample since the S is somewhat of a rare bird. And the HP2 - again, a rather rare bird.
    But - in the interest of completeness - people with '05/06 bikes - please let us know if you have the OBC (fuel level display/miles to empty)..
  5. #35
    Quote Originally Posted by davesbmw View Post
    Don
    Dave
    I see two failures now reported for '05.. some details on what failed/how and if there was any pattern of repeated failures would be good info to have (HINT!)
  6. #36
    Quote Originally Posted by Weasel View Post
    I had 3 fuel strips on my '10 RT, but already voted for the '10 model, so I couldn't vote for multiple failures...none, yet, on my '11 RT.
    Actually - you can - I've allowed multiple choices for the poll just for that reason, and that people may have owned multiple bikes in the year range and experienced failure (or not) on one or more bikes.
  7. #37
    Update!
    UPDATE: I accidently forgot that the 2012 R1200R still was delivered with a fuel strip. If you have had a failure - please log it under the 2011 model, and make a note in a posting. I'd edit the poll, but I think that clears it of all results.
    I should have realized this since a friend with a 2012 has a bum fuel strip..
  8. #38
    Snip....
    I HOPE he is the only one.
    David
  9. #39
    Apr 2009
    Cincinnati, Ohio
    2009 r1200GS and the fourth one just quit.
    2009 R1200GS
  10. #40
    Dec 2009
    Hudson Valley, NY
    No (knock wood) fuel strip failure on my '09 RT.
    Craig
    2009 R1200RT
    MOA #146131 IBA #55715
  11. #41
    Sep 2003
    Virginia Beach
    If we can go back and re-vote for multiple fuel strip failures, please provide instructions...
    Virginia Beach
    current:14 R1200RT 75 R60/6
  12. #42
    RealOEM says the part number for "Fuel pump unit with lever sensor" on my '05 GS is 16 14 7 684 348. Looking for that part number RealOEM says it was used on the "GS 04" and "GS Adve. 06" models. Looking at 06/'06 GSA. I see a picture of the strip, but the table gives two options: the above part for "On-board computer = No" and a different fuel pump plus the strip sensor for bikes with the OBC.
    The bike gives a countdown to out of gas when you get to approx 1 liter of gas left in the tank with the float/lever sensor, too.
  13. #43
    R1200RT No fuel strip issues (Yet??)
    2006 R1200RT with no issues with fuel strip so far. Got my fingers crossed.
  14. #44
    2007 R1200R FLbmw's Avatar
    Aug 2005
    Florida
    '07 R12R, 35,000 miles on the original strip
    Russ
    BMWMOA Life Member
    AMA Life Member
    300,000 BMW miles and riding
  15. #45
    On the Road
    Sep 2009
    Isanti, MN
    2009 RT 30K miles, took 2 replacement strips to fix it.
    Bill
