View Poll Results: Have you had at least ONE fuel strip fail?
Voters
670. You may not vote on this poll
  • YES - 2005 model year
    38 5.67%
  • YES - 2006 model year
    26 3.88%
  • YES - 2007 model year
    77 11.49%
  • YES - 2008 model year
    92 13.73%
  • YES - 2009 model year
    130 19.40%
  • YES - 2010 model year
    47 7.01%
  • YES - 2011 model year (R1200R only I think..)
    21 3.13%
  • YES - Multiple fuel strip failures - please note model/year in a comment
    54 8.06%
  • NO - fuel strip failure. Please note year/model in a comment
    228 34.03%
Multiple Choice Poll.
Page 1 of 29 1 2 3 11 ... LastLast
Results 1 to 15 of 432
Thread: Fuel strip poll
    Fuel strip poll
    This is a simple poll to try to gather some info on what the failure rate of fuel-strips for various year bikes was.
    Since this will include some years where BMW used both strips and a float assembly, I'll try to take that into account. If you've had multiple fuel strips - please note that in a comment.
    * I'm making this an open poll, so usernames will be visible (if you care) for the poll results.
    * I'm also allowing more than one selection since some members may have more than one bike in the years covered.
    Right at the beginning - I'll sticky it so it stays up top. Once it has served it's purpose it will be un-stickied.
    UPDATE: I accidently forgot that the 2012 R1200R still was delivered with a fuel strip. If you have had a failure - please log it under the 2011 model, and make a note in a posting. I'd edit the poll, but I think that clears it of all results..
    UPDATE #2: This seems to have not been clear enough, so in case anyone actually reads this before voting:
    THIS POLL ALLOWS MULTIPLE CHOICES:
    • Example: If you have a 2007 R1200xyz and a 2008 R1200xyz - and both had failed fuel strips - you should check both off.
    • Example: If your 2007 R1200xyz had more than one failed fuel strip - you could check off the option for multiple failures. That selection should only be clicked on IF you had multiple failures on ONE bike.
    • Example: If you also own say a 2009 R1200xyz and haven't had a fuel strip fail - you can check that off also (and please note this, with year/model in a comment/posting after voting.)
    The intention of the poll is to get an idea of the yearly distribution of failures. It is not intended to be scientifically valid, since that's impossible with the simple polling mechanism Vbulletin allows. I also do not have the numbers of bikes sold each year with fuel strips - so that is also a consideration. Some models were not produced in some years, which will additionally skew the results.
    Thanks for voting, the results are interesting (but not scientifically conclusive by any means) so far.
    Last edited by deilenberger; 10-29-2012 at 04:24 PM. Reason: Missed a model year..
    Comment example
    I have an '07 R12R - 4 strips to date. All on BMWs dime.
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    07 - on the 5th. One on BMW - three under Extended Warranty. This last one craps out - it's on me.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    AVELLA PA
    09rt
    Not one thing in 17k miles
    Bloomington, IL
    09 r1200gsa
    On strip number 5 at 35K miles.
    Chuck Manley #12106
    2012 Howlin' at the Moon Rally Chair
    Ambassador, Knights of the Roundel #333, IBA Member, Life Member NRA
    Black '13 R12GSA (the Outlaw), Black '02 K12RS (157K)
    Jul 2007
    THE BIG SKY
    No 2008 R1200R
    No 2007 R1200RT
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    I voted no, but I suspect that is really "not yet" Over the last year I've seen a couple of funky results and have been expecting it to go. Hopefully it will go before the factory warranty runs out.
    2009 BMW R1200GS Adventure.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA 2013 K1600GT
    Feb 2010
    Cape Cod, MA
    08 GSA 18000 miles Original strip.
    John Simonds
    2008 R 1200 GSA
    1975 Norton Commando 850 Roadster Mk 3
    If it ain"t broke... fix it till it is.
    Jul 2010
    Lansdale, PA
    05 R1200RT 25000 miles on original strip.
    8 strips failed
    08 R1200R 6 strips in 12 months
    08 1200GS 2 strips failed in 4 months 1st lasted 24000 miles
    Thanks Don for doing this
    Dave
    Quote Originally Posted by j.castiglia View Post
    Were is the "comment" section where I can post the year? I voted already, can I go back and edit it for the comment?
    You just made a comment in the comment section..
    Registered User widebmw's Avatar
    Reno, NV
    2009 R1200GS 48,000 miles still on the original strip.
    add it in your reply here...you can edit your post using the button on bottom right
    My 09 GSA is on # 3 ,first was around 26K now at 70K. '05 RT had no issues at 58K
    My R12S doesn't have one!
    Steve Henson
    Clovis, NM
    No, but you can go back and comment in your request to locate the comment section but editing your comments on where to comment.
    Or not.
    Nom de Plume:
    BMW MOA #6218
    IBA# 442
    Registered User ezec's Avatar
    Aug 2011
    Arkansas
    2010 rt
    11k miles, no problem
    2010 R1200RT
    GO HOGS!
