View Poll Results: Have you had at least ONE fuel strip fail?
Voters
663. You may not vote on this poll
  • YES - 2005 model year
    37 5.58%
  • YES - 2006 model year
    26 3.92%
  • YES - 2007 model year
    76 11.46%
  • YES - 2008 model year
    91 13.73%
  • YES - 2009 model year
    129 19.46%
  • YES - 2010 model year
    47 7.09%
  • YES - 2011 model year (R1200R only I think..)
    20 3.02%
  • YES - Multiple fuel strip failures - please note model/year in a comment
    53 7.99%
  • NO - fuel strip failure. Please note year/model in a comment
    226 34.09%
Multiple Choice Poll.
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 424
Thread: Fuel strip poll
Hybrid View
    Fuel strip poll
    This is a simple poll to try to gather some info on what the failure rate of fuel-strips for various year bikes was.
    Since this will include some years where BMW used both strips and a float assembly, I'll try to take that into account. If you've had multiple fuel strips - please note that in a comment.
    * I'm making this an open poll, so usernames will be visible (if you care) for the poll results.
    * I'm also allowing more than one selection since some members may have more than one bike in the years covered.
    Right at the beginning - I'll sticky it so it stays up top. Once it has served it's purpose it will be un-stickied.
    UPDATE: I accidently forgot that the 2012 R1200R still was delivered with a fuel strip. If you have had a failure - please log it under the 2011 model, and make a note in a posting. I'd edit the poll, but I think that clears it of all results..
    UPDATE #2: This seems to have not been clear enough, so in case anyone actually reads this before voting:
    THIS POLL ALLOWS MULTIPLE CHOICES:
    • Example: If you have a 2007 R1200xyz and a 2008 R1200xyz - and both had failed fuel strips - you should check both off.
    • Example: If your 2007 R1200xyz had more than one failed fuel strip - you could check off the option for multiple failures. That selection should only be clicked on IF you had multiple failures on ONE bike.
    • Example: If you also own say a 2009 R1200xyz and haven't had a fuel strip fail - you can check that off also (and please note this, with year/model in a comment/posting after voting.)
    The intention of the poll is to get an idea of the yearly distribution of failures. It is not intended to be scientifically valid, since that's impossible with the simple polling mechanism Vbulletin allows. I also do not have the numbers of bikes sold each year with fuel strips - so that is also a consideration. Some models were not produced in some years, which will additionally skew the results.
    Thanks for voting, the results are interesting (but not scientifically conclusive by any means) so far.
    Last edited by deilenberger; 10-29-2012 at 04:24 PM. Reason: Missed a model year..
    Comment example
    I have an '07 R12R - 4 strips to date. All on BMWs dime.
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    07 - on the 5th. One on BMW - three under Extended Warranty. This last one craps out - it's on me.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Quote Originally Posted by SteveAikens View Post
    Check recall they may cover up to 12 years. BMW dealer changed my 06 rt last month
    Question fuel strip problem
    I have a 2005 Rt and I had purchased the bike in 2011 with 5500 miles on it. I had it for 3 months then the strip went. Didn't bother to replace the strip back then because BMW wasn't paying the $335 to replace it. Lived with it until 2014 when at 18000 miles BMW said they would warrant it for 12 years after date of inception. Gave me a warranty until 2017. Less than 500 miles after bikes they repaired it ,the strip went again. Now it's june 2015 and they're going to repair it when I get it to the shop.
    A German tour guide on a motorcycle trip in Italy told me something that makes a lot of sense. BMW never repairs a problem as soon as it happens. Here it is 2015 and only recently have the 2014's been replaced, so I have heard, with a new fuel strip or float sensor. From 2005 to 2014 they just keep replacing these things and never try to fix the problem or find any solution to the problem. This is german engineering ?!?!
    AVELLA PA
    09rt
    Not one thing in 17k miles
    Bloomington, IL
    09 r1200gsa
    On strip number 5 at 35K miles.
    Chuck Manley #12106
    2012 Howlin' at the Moon Rally Chair
    Ambassador, Knights of the Roundel #333, IBA Member, Life Member NRA
    Black '13 R12GSA (the Outlaw), Black '02 K12RS (157K)
    Jul 2007
    THE BIG SKY
    No 2008 R1200R
    No 2007 R1200RT
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    I voted no, but I suspect that is really "not yet" Over the last year I've seen a couple of funky results and have been expecting it to go. Hopefully it will go before the factory warranty runs out.
    2009 BMW R1200GS Adventure.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA
    Feb 2010
    Cape Cod, MA
    08 GSA 18000 miles Original strip.
    John Simonds
    2008 R 1200 GSA
    1975 Norton Commando 850 Roadster Mk 3
    If it ain"t broke... fix it till it is.
    Jul 2010
    Lansdale, PA
    05 R1200RT 25000 miles on original strip.
    8 strips failed
    08 R1200R 6 strips in 12 months
    08 1200GS 2 strips failed in 4 months 1st lasted 24000 miles
    Thanks Don for doing this
    Dave
    R1200RT Artiee's Avatar
    Jul 2008
    Northern Virginia
    No Fuel Strip Failure
    2005 RT....
    Now that I've said it, I'm probably jinxed.....
    100,000 miles
    Experience IS NOT the best teacher! Someone else's experience is the best teacher.
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    no strip failure
    2006 RT traded in with 68000 miles
    2014 R1200 GSA W
    2016 S1000XR
    Riding is the art of throwing yourself at the ground and missing
    Registered User hrvatin's Avatar
    Jan 2008
    Salem, Ohio
    2008 RT, currently on number 3, I paid for #2, and #3 was under warranty.
    Approx 9,000 miles now.
    Hrvatin
    Northeast Ohio
    2008 R1200RT
    1984 R65
