Results 1 to 15 of 17
Thread: 1992 K75 fuel pressure control
Hybrid View
    broadstone
    Hi. I'm still trying to get my K75S running and have a question about pressure in the fuel rail. I'm taking the previous owners word that the fuel pressure was tested and found to be within specifications. Even after sitting for 2 days, when I remove the fuel line there is enough residual pressure to blow a stream of gasoline out. I know I'm missing something that should be obvious but I don't understand how the fuel pressure is controlled since the fuel return line is unrestricted in the '92 because there is no in-line regulator. It appears that when fuel enters the rail there is nothing to impede its direct return to the tank. So how is the rail pressurized? BTW, the only time it runs at all is when it's running out of fuel or the fuel line is disconnected ( for a few seconds).
    Apr 2007
    Rockport, TX
    Unless you relieve the pressure in the line before removing the tank you WILL have gas squirt out for a few seconds; simply run the engine, disconnect the fuel pump voltage connector on the back lower right side of the tank and the engine will stop running a few seconds later.
    THEN you can disconnect the fuel lines or remove the tank without gas shooting out.
    ---Jeff
    The fuel comes out of the pump (capable of 100psi) in the tank, through the filter (also in the tank),and out the rear nipple on the left front lower edge of the tank.
    It goes through a hose (about 8" long) to the front of the fuel rail, where the injectors draw the fuel from.
    At the rear end of the fuel rail is a hose that goes to the fuel pressure regulator. The fuel pressure regulator is hidden behind the throttle bodies between the throttle bodies and the air filter box.
    The fuel pressure regulator bleeds off any pressure above 38psi. That bled off pressure goes forward through a hose back to the tank through the nipple just forward of where it came out of the tank.
    So the fuel rail pressure should stay at about 38psi unless the fuel pressure regulator is defective. It can fail either too high or too low.
    Don't EVER rely on previous owners troubleshooting when trying to get a bike running. VERIFY!!! Remember, he couldn't get it running before he sold it (thereby losing at least $1000 in the sale), so he wasn't a very good troubleshooter.
    The best way to test the pressure is to TEE a gauge between the rear of the fuel rail and the hose that goes to the regulator.
    You have already pulled and inspected the pump,damper,pickup sock and inspected the bottom of the tank where the fuel is picked up and CHANGED the filter, right?
    IF those are OK, the other fuel issues might be clogged injectors, failed regulator (TEST pressure!), or a sticking air flow meter.
    broadstone
    K75S fuel pressure
    O.K., here's the latest and, keep in mind that this bike sat unused outside with a tarp over it for over two years. I couldn't find the fuel pressure regulator but I tried blowing and sucking air through the return line but could move no air through it. So I disconnected the regulator air hose from the manifold in an attempt to open the regulator by using my mouth to create a vacuum. That didn't work so I tried putting a better vacuum on the line using a vacuum brake bleeder. I pumped it to -25psi and still could not blow through through the return line. From this I assume that the regulator is frozen closed or that the hose is seriously kinked in some location not visible from either side. The frozen closed regulator seems the best conclusion because in inspecting the inside of the tank some of the steel parts such as fuel pump retaining nuts are rusty. I'm going to wait for your ideas before trying to get at the regulator which looks like it will be a major undertaking for a novice.
    That is not a valid assumption! The regulator only passes pressure IN EXCESS of 38psi.. There is no way you are creating that kind of pressure with your lungs.
    Quit messing around and do a pressure test WITH a GAUGE!
    Odds are that's not the problem, but until you know FOR SURE what the fuel pressure is all your other troubleshooting will be based on an assumption. Getting a bike that hasn't run for years and you have no information about takes slow METHODICAL checking to establish what is right and what is not.
    Jun 2012
    Olympia, WA
    Accessing the regulator is not too hard. Just remove the air box.
    • Unscrew and remove the plastic intake manifold. you can wiggle it out of the air box.
    • Loosen the hose clamp on the hose on the front of the air box. (#1)
    • Unlock the three clips (#3) (and maybe remove them) and remove the air filter
    • Gently pull out the top of the air box, remembering that it is connected with a wire to the air flow meter. Let it hang.
    • Remove the two allen screws that connect the air box bottom to the engine block.
    You'll probably find a bunch of bugs and stuff you'll want to clean out of the lower airbox. I also found 20 years of baked-in dirt and pebbles on the engine top under the airbox. Had to scrape and vacuum that out.
    Apr 2007
    Rockport, TX
    While removing the airbox is a necessary evil to gain access to the FPR it is not really all that easy as Tim claims above---in my opinion and experience. I just finished installing a new aftermarket regulator which ended up requiring me to remove/reinstall the airbox twice in a week's time.
    First of all, you WILL need to remove the tank just to access the retaining clamps screw on the FAR SIDE of the large intake tube. Once the tank is off you will then be able to poke a long flat blade screwdriver (or really extra long nut driver) down through the nest of wiring to reach the screw. Be careful not to loosen it too much as then the retaining clamp will slide out of range---and if you forget to set into position when reinstalling things you won't be able to tighten it back up.
    DO NOT try to remove the tube from the airbox side as it will not come out and off until you can swing the airbox out of the frame. Believe me, I learned all of this the hard way.
    The good news is that once you learn the technique it becomes almost easy as described above. The airbox is really wedged into the frame/engine area tightly and there's precious little room to do things. Unless you have really small hands (I enlisted my wife's help) it is an absolute PAIN to get the 3rd spring clip back on the back side of the airbox upon reassembly. It is also imperative that the air filter goes in the one, correct way otherwise you will struggle to no end.
    If you apply a tiny bit of Armour All or Back To Black lubricant along the top and bottom edges of the air filter it will snap back into place a whole lot easier, too.
    I would also advise using a long pair of forceps to position the 3rd spring clip as I did the last time I put mine back together the other day---it worked so well I'll never try doing so without one (they're available at Harbor Freight for a few bucks).
    All of what I've written may be in vain, though---as I agree with 98Lee that you should go through the bike methodically and check other things first. Especially true since your bike sat for so long; all kinds of gremlins are bound to appear.
    I'm almost in the same spot as you with problems that I thought were one thing but may turn out to be something else completely (see my Chirping Noise While Hot thread if interested; my current nightmare of sorts!).
    Good luck and do heed Lee's and other's advice here; they really know how to help you with your Brick.
    ---Jeff
    Jun 2012
    Olympia, WA
    Quote Originally Posted by Zagando View Post
    ...you WILL need to remove the tank just to access the retaining clamps screw on the FAR SIDE of the large intake tube. Once the tank is off you will then be able to poke a long flat blade screwdriver (or really extra long nut driver) down through the nest of wiring to reach the screw....
    I forgot about that I flipped that clamp over when I reassembled so that I can loosen it with just a long screwdriver from the bottom/front. I don't have the RT fairing installed anymore either, so that makes things easier.
    K75RT Keith
    Apr 2011
    Rocky River Ohio
    I may have missed your response so let me ask, What parts have you already inspected cleaned and/or replaced?
    Has the air filter been changed? The air box cleaned out? I found a mouse nest, nuts, rocks and who knows how much mouse poop in a bile that sat for a couple years.
    Do you have good spark?
    Can you hear the pump run when the ignition is turned on and the starter button depressed?
    Have you pulled the fuel rail and checked that the injectors are squirting?
    broadstone
    1992 K75S fuel pressure
    98Lee, I quoted the wrong book in referring to relieving fuel pressure. It was on page 6.5 (middle of page) of the 1999 Haynes manual that discusses alternative methods of releasing fuel pressure from the rail. It makes sense to me that this would work but, indeed, I still wasn't able to blow air through the return line even with nearly -40 psi of pressure applied to the vacuum line at the throttle body. Because of the significant task of getting to and removing the FPR, I'm actually hoping that someone will convince me that my conclusion re a frozen closed regulator is wrong. Thanks again.
    Astatula, FL
    Quote Originally Posted by broadstone View Post
    There have been numerous recommendations telling you to do an actual check of the fuel pressure. Without that knowledge you can not diagnose any further.
    The parts are available at any box store; a brass tee, some barbed hose fittings to screw into the tee, a cheap pressure gauge from the water well section, some fuel hose and some clamps.
    Less that $20 material, less than 20 minutes to put it together and hook it up.
    If your pressure is in the 38 psi range your FPR is fine. If the pressure is high, then you may be correct in your assumption.
    No other way to confirm that than to do the test.
    Following that I would look at pulling the injectors and to see if they are frozen open. If open you should be able to blow through it. You can apply 12V to an injector and should hear/feel it click as it moves. They can be cleaned locally, look for a diesel injection service.
    I know this because I had stripped my former 89 K100RS down for paint, basically had the fuel rail open when I ruptured a disc in my back. 8 months later I was getting everything back together and couldn't get the bike to run. Pressure test showed the FPR was fine, but I found the injectors to be frozen.
    Bob Weis
    '04 K12RS - Hannigan Hack
