Results 1 to 6 of 6
Thread: '90 K75S Fork Spring Caps
    Registered User jkbales's Avatar
    Dec 2009
    Marietta GA
    I want to remove the fork spring caps to replace the springs, but I can't get the caps off. The caps depress only 1/16 inch, so can't get at the snap ring. These are "S" forks, still on the bike. What am I doing wrong?
    John
    Current: '15 R1200RT Ebony Metallic
    Past: '10 R1200RT, '09 R1200RT, '04 R1150RT, numerous Suzuki, Yamaha, Honda, Kawasaki, & Harleys
    Take a bar ( I use an Allen socket that fits the filler and an extension) and push down on the cap. It will expose the snap ring. Once the snap ring is removed, CAREFULLY release the spring pressure on the cap. There is about 1" of spring preload on the cap.
    You MIGHT have to tap the extension with a hammer and use most of your weight to compress the spring enough to get at the snap ring.
    Dec 2009
    Marietta GA
    Thanks, I'll try it. I used a "T" bar with a socket to push the cap down, after I removed the filler plugs. Maybe I wasn't pushing down hard enough, only about 50 lb. The front of the bike is jacked up, but I didn't want it to rock forward off the center stand. I'll get a helper and see if I can wedge the rear brake on, to steady things.
    John
    Have the helper sit on the back of the bike and or block up the bottom of the engine or the mounting bushings of the engine spoiler.
    Dec 2009
    Marietta GA
    I got it! The cap was stuck due to corrosion and it took 3 taps to loosen it, then only moderate pressure to hold it down. The clip was slightly rusted but came out OK. Thanks for the tips.
    John
