Results 1 to 11 of 11
Thread: Remove Ignition switch RT?
    PSL, FL
    How do you get the ignition switch out of the RT fairing? Does that little plastic piece just spin off?
    Oct 2009
    Northern Cal
    Quote Originally Posted by les_garten View Post
    There should be a black anodized aluminum ring with to small holes in it for a pin wrench. Unsrew it and it will come out from behind the dashboard.
    www.boxermetal.com
    www.facebook.com/boxermetal
    PSL, FL
    Quote Originally Posted by bmweuro View Post
    That's how I thought that worked, but that rascal is too tight for 2 small phillips screwdrivers.
    Any other makeshift tool you can use?
    Oct 2009
    Northern Cal
    I'm not sure. I bought the factory tool 20+ years ago.
    www.boxermetal.com
    A pair of snap ring pliers is what some of the old manuals suggest, and what I have used since 1977. The type that can be converted from internal to external, in an appropriate size seems to work best.
    PSL, FL
    Quote Originally Posted by lostboy View Post
    I tried one of those earlier, not much luck.
    Maybe some Kroil and a second try tomorrow.
    Thanx!
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I'd put some lube (perhaps a silicone-based one) on the outside of the ring, and give it some time to dribble into the threads that hold the ring in place. Then, needle-nose pliers, held perpendicular to the ring with the tips in the holes, and carefully rotated. Keep some downward force (pushing the tips in the holes) on the pliers as you rotate them.
    David Brick
    Santa Cruz CA
    2007 R1200R
    PSL, FL
    Thanx as well. Got it soaking right now.
    Oct 2009
    Northern Cal
    I can send you the tool but I need someway of knowing I will get it back.
    www.boxermetal.com
    Pismo Beach, CA
    aka: a deposit. Perhaps?
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    PSL, FL
    Thanx Bro' got it off with some small electrical needle nose.
