Results 1 to 5 of 5
Thread: Procedure for touching up paint?
    Bluegrass Rider Kentuckyblue's Avatar
    May 2006
    Central KY
    Is there some sort of clear coat that you should apply over an area touched up with paint?
    2007 K1200LT/Hannigan - Blue
    2012 R1200GS Rallye Edition
    1973 R75/5 Toaster LWB - Black
    ColorRite
    Have you checked out ColorRite?
    Eastern KY
    You do not need color rite for clear coat repair as there is no tint to clear. Is there damage to the base coat which has the color? You might also avoid clear coat & just touch up with a lacquer repair color as mentioned in this forum-search. recent threads.
    Go to Wally World & buy a clear touch up thingy. The real technique comes into play in being able to make the repair as un-noticeable as possible via either careful application or wet sanding with micro grit paper & polishing the area. Takes practice to avoid erosion of the surrounding area!
    DNORDINKGT
    Quote Originally Posted by Kentuckyblue View Post
    I just did some touch up with colorite and it definitely needs a clear top coat. In my case the bike appeared to have been dropped in the garage and it had some gouges, it tried sanding everything down and then applying colorite paint using a good brush, and honestly I think I should just left it alone and chalked it up to a character mark, because the damage is still quite noticeable.
    If you want my opinion I would opt for the Dr. Colorchip solution, I have had better luck with their stuff and did not have to clear coat it afterwards.
    Eastern KY
    I'd be happy to look at the area you want to repair(and advise) sometime I'm in Lexington, if that's helpful to you?
