Results 1 to 4 of 4
Thread: R1200R USA vs International Specifications
    Question R1200R USA vs International Specifications
    R1200R
    BMW Motorrad USA site says SOHC.
    BMW Motorrad International site says DOHC.
    Are they both correct?
    Quote Originally Posted by Undermoose View Post
    R1200R
    USA 2010 and up DOHC I have one.
    Spring Lake NJ, USA
    Sounds like the BMW US site needs an update. The original hexhead engine has a single camshaft mounted lower in the head that uses small followers and pushrods to activate rockers that open the valves. The "camhead" engine has camshafts - two of them per cylinder (hence DOHC) that sit higher in the head, which almost directly act on the valve (no pushrod, no rockers) through a finger follower where one side rides on the cam lobe, the other side has a semi-sphere (1/2 sphere) that presses down the valve stem opening the valve, and the sphere comes in different sizes so the clearance can be adjusted.
    Whew.
    Short story - BMW Motorrad US website is screwed up. Not a surprise.
    Spring Lake NJ, USA
    Quote Originally Posted by DROOT153718 View Post
    Almost. The R12R didn't get the camhead engine until 2011..
