Results 1 to 10 of 10
Thread: K13GT 18K service list
    Feb 2011
    Illinois
    Does anybody have/know the 18K service work sheet for the K 1300 GT?
    I'll really appreciate it if you can share it.
    Safe riding
    Damian
    Steve Henson
    Feb 2011
    Illinois
    Thank you for the link.
    I don't see how often the valves have to be checked/adjusted.
    Is this the 18000 miles list or 6-12k?
    Thank you for your help
    I linked the annual/12K and the 6K intervals I believe...at 18K, it should only be oil& filter off the top of my head. every 6K oil change so an 18 is between majors
    here is the one with valve check listed...
    http://www.ascycles.com/pdf/ServiceS...12K_Annual.pdf
    24K valve check is what was typical on the K12's I wonder if it's higher now?...I have checked four in that zone and one at 36K with no out of tolerance found.
    And it's no picnic getting to that area...the first time can scare you!
    You'll need a vacuum set up to refill the coolant safely w/out air in the system.
    There is a post here with a how to...and more info over in the K bike forum. If you have not visited there, just take some of the postings of gloom and doom in stride...some are true...some are a little dramatic It's more International and chatty!
    http://www.k-bikes.com/forums/cmps_index.php?
    Steve Henson
    Feb 2011
    Illinois
    Thank you Steve,
    It sounds good and easy this time at 18K.
    (When the time comes I will take the GT to a BMW mechanic to check and adjust the valves if needed)
    I really appreciate your help
    Safe riding
    Damian
    Nibley, UT USA
    First valve check is at the 18k service, and along with it the first sparkplug change-- as per the sheet referenced above at the A&S site. BMW calls for checking valve clearance every 30000 kilometers (18k miles). Beyond that, the 18k service adds the normal 6k stuff-- oil, filters, etc.
    I wouldn't put off that 18k service much over 18.5k if it were my bike. While you're having the 18k done you might also want to see about the cam chain jump guard, which is now a recall in the UK but not here in the US. Also, be sure to ask for some kind of documentation on what the valve clearances actually measured at so you can track change over time/miles. I'm hoping the wedge Ks run like the brick Ks, where after the first 36k valve checks were really only needed every 24-36k or so.
    Best,
    GTRider
    DGerber
    1983 R80ST -- 1988 K100RS (r.i.p.) -- 1995 R1100RSL (gone, never forgotten) -- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    Feb 2011
    Illinois
    Thank you Gtrider,
    I appreciate your help.
    I just bought a repair/service manual dvd and it shows it the same way you say it is.
    30000KM
    Regards
    Damian
    My bad...my local had it listed as 24k when we picked both ours up...Helen's never had any documented check when I checked at 36K after she bought it...all was well. I have the first year repROM available...I need to go look at it again.
    Isn't the jump guard standard on the 13's? the tensioner update was.
    Steve Henson
    Debbie's Servant Lee's Avatar
    SW Iowa
    Not the early 1300's.
    Our 2011 K1300S's were built near the end of Aug 2010 and do not have the guards. I think BMW started to install them at the factory around early 2011.
    I was planning to do the jump guard update on our bikes this fall or winter, but decided to hold off on ordering the parts when I saw the UK has a recall now.
    Maybe the US will make this a recall also.
    Lee 2011 K1300S
    MOA # 30878
    Nibley, UT USA
    Build date on my 2010 K13GT was Jan 2010 and it did not have the jump guard installed, so if they were added as an assy line item it had to be after Jan of 2010.
    Best,
    GTRider
    DGerber
