Results 1 to 13 of 13
Thread: Duhh
    Atomic City Boxer 154048's Avatar
    Nov 2009
    Santa Fe, NM
    Duhh
    After years of wrenching I proved that you are never too experienced to ignore the tried and true axioms...like not leaving a critical juncture un done...
    Routine oil change....left the pan draining while I went and had lunch...came back and fired it up...:dang, those valves are noisy"....Ooops.
    Only ran for 10 seconds or so, but honestly...duhhh
    Back to Basics School for me....
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
    Albuquerque, NM
    Time for a checklist?
    Kent Christensen
    21482
    Mar 2008
    DeLand Florida
    Saw a mechanic do the same thing at a Chevy dealership. After gunning the engine several times to get the oil light to go out, he shut it down. He looked over at his work bench and saw the oil, put it in and returned the truck to the customer. I wonder if this shortened the life of the engine.
    Jul 2010
    Tularosa, NM
    Reminders. . .
    Uhhhh, now where the hell did I put that checklist?
    I've learned to use post-its, attached with little zip-ties (fortunately, cheap at Harbor Freight - I use a lot of them) through fastener holes, un-torqued nuts, de-tached electrical connections, and - most especially, around the ignition-area when the bike has NO OIL in it. . . Before I'm done with a big set of of jobs, the bike looks like an explosion in a paper factory.
    Sad to say, that I'm now capable of forgetting ANYTHING. In fact, what were we talking about?????
    Walking Eagle
    May 2012
    VA
    That is easy to do. With life's almost constant distractions, any time I take a break when working on something (and I am always working on something) I try to leave the job so if I don't come back for several weeks there should not be a problem. That includes photo's, labeling baggies w/parts, and putting bolts and nuts back finger tight so they don't get lost. Even then, things happen. I try to not get distracted or take long breaks when changing engine oil - also people have described using the starter to crank the engine to get the oil light to go out before starting, which does work. Now you know, don't take a lunch break in the middle of changing engine oil.
    Stan
    AH# 13238
    Nov 2009
    Santa Fe, NM
    Excellent tips...
    I usually at least take the key out and hang it up with a note attached so it is not so tempting to listen to that lovely Boxer sound...
    Until it is time....
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
    jimmy armour
    Jul 2009
    Lucknow ontario canada
    old timers
    thats what I do,I remove the key and place it in the container with all the nuts screws and ,cleaned oil filler/drain plugs,why ?, because I have also started a few bikes over the years, owned by myself and some friends ,while I was working on them ,luckily all were ok and ran for thousands of miles after,hope all is well ,jimmy
    Nov 2009
    Central Ontario, Canada
    yellow post it not on my tank right now... "NO OIL"!
    I don't trust myself: I might forget to fill the oil after leaving it for a couple days until I can get around to picking up some oil that I thought I had before I drained...
    Yep... note pad is becoming an important part of my tools.
    '81 R80G/S(wp4860 forks, Henderson triple clamp)
    '10 Husaberg FE450, '10KTM 250XC-W
    Past BMWs: '68 R50/2, '77 R80/7, '87 R80GSPD, '76 R60/6, '85 K100RS, '91 R100GS,'87 R100RS
    Sep 2006
    I use pink surveyor tape on items on the checklist to be removed/tightened/checked.
    Like the TDC locking tool! and on the keychain of bikes NOT to be started until final check.
    Steve Henson
    Registered User PeoriaMac's Avatar
    Aug 2003
    Washington, Illinois
    Perhaps not as damaging to the engine, but certainly messier is forgetting to replace
    the oil filler cap before starting the engine....
    Mac
    1986 R80RT, 2005 R1200GS
    Livin' Large On The Lake
    Apr 2012
    Gilbert, AZ
    Or not replacing the drain plug before refilling with oil, esp. after you've already removed the drain pan.
    Not that I've ever done that...
    2004 R1150RT
    BMW MOA 181289
    I put my bulky obnoxious funnel in the filler hole
    Its high VIS yellow, sticks out and hits the fuel petcock and if I don't notice it then I should all my bikes because I'm obviously blind.
    For the Oil and Hex head machines the funnel is a little different and it doesn't hit the petcock but its still nearly impossible to miss.
    The cap comes off and the funnel inserted before the oil is drained, I have done this since my days as an MB VW tech, I was mentored by a very wise individual.
    I like the idea of putting the key in with nuts bolts and other related items but I have a few "in progress" projects and I may not find the key until that particular project is finished.
    Jul 2007
    THE BIG SKY
    Unhappy
    I'd never forget to put the oil in; that would be silly. Nope, I remembered to put the oil in my cage. It was the drain plug I neglected to put in. Five quarts of oil on the ground in front of my place in Germany. The Germans were not amused.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
