Results 1 to 8 of 8
Thread: 2005, R1200RT, Valve noise?
    Registered User Spinakr's Avatar
    Nov 2007
    Vancouver... Not B.C... Washington... Not D.C.
    Question 2005, R1200RT, Valve noise?
    Current Mileage, 28,598
    Several months ago I performed the Valve Adjustment as described in the HEXHEAD Tech section. Used .30mm gauges for exhaust and .15mm gauge for the intakes. All went well and I double checked my work. Ever since, I have noticed a pronounced tick from the left cylinder. So, I purchased the VonBaden video and METICULOUSLY performed the procedure again, literally following Jim's video step by step; Including checking the rocker arm endplay.
    The tick is still there...
    Is this normal?
    Any thoughts are much appreciated
    Vancouver, WA
    BMW MOA #136722
    Mar 2005
    Clinton, TN
    injector tick
    Shield the injector with your hand and see if the ticking goes away. An injector can be pretty loud.
    Dan
    2010 R1200GSA
    Nov 2007
    Sounds lower in the engine
    I tried muffling the injector the best I could without removing any of the fairing.
    Listening around the engine though, it definitely sounds like it's coming from lower than the injector.
    Vancouver, WA
    BMW MOA #136722
    Did you, can you set rocker shaft end play?
    I set my oilhead to absolute minimum. Quiet as can be.
    David
    Nov 2007
    Yup,
    Rocker shaft endplay is perfect.
    Vancouver, WA
    BMW MOA #136722
    Mar 2005
    Clinton, TN
    Maybe this would help
    from Harbor Freight- http://tinyurl.com/8wb5w8l
    Or a long screw driver...
    to isolate where the tick is coming from.
    Dan
    2010 R1200GSA
    Mar 2004
    Alexandria, VA
    Check your exhaust at the head. You might have a very small leak.
    Jim
    Nov 2007
    Re: Exhaust leak
    I'll do that!
    Thanks Jim.
    BTW, I'm enjoying your R1200 Maintenance video, very helpful!
    Vancouver, WA
    BMW MOA #136722
