Results 1 to 10 of 10
Thread: turn signal gaskets r75/5 (adhesive? yay? nay?)
    Apr 2012
    Los Angeles, CA
    Hi all,
    The turn signal gaskets on my r75/5 are the old white/grey and have become hard dried up remnants of its past 40 year life.
    I was about to order turn signal gaskets from bmwhuckys.com
    I noticed in the photos these gaskets are cut (they appear more like a rubber string of sorts). Is there a specific type of adhesive I should use when mounting these? is adhesive even supposed to be used on them at all to affix them to the lights?
    Also i suppose this same question applies to the tool tray and its gasket as well.
    My tool tray is filthy and the old gasket is also bad. Was wondering if anyone had a good suggestion on trying to clean the tool tray up to look nice and new again and also what type of adhesive is best to affix its gasket as well?
    Is it better to just replace the tool tray entirely? Or do you think it would be able to clean up well?
    turn signal gaskets?
    I used large Oring rubber s
    Sep 2004
    Arlington, TX
    Turn signal gaskets
    The gaskets are cut for a reason. The split should be on the bottom so that any water can drain. Look at the lens bottom and you'll see a gap.
    Last I checked, the new gaskets are still available from BMw but are black in color. Eurotech (now out of business) had a kit available with the correct color. Boxers By Bruce may have some of them as well. The kits also included the black plastic washer that goes under the head of the screw.
    Just use a small ammount of "super glue" to hold them on.
    Boxerbruce
    Oct 2009
    Northern Cal
    Quote Originally Posted by jbf View Post
    Hi all,
    There is a solution. Check your PM's
    www.boxermetal.com
    www.facebook.com/boxermetal
    Apr 2012
    Los Angeles, CA
    When you say superglue you mean the plastic rings for the screws or on both screws and gaskets?
    Sep 2004
    Arlington, TX
    superglue
    Just use a few drops on the gasket. Leave the washers dry.
    Boxerbruce
    Sep 2003
    Virginia Beach
    I didn't use any glue on my signal gaskets and they have been fine since I replaced them 5 years ago. Also, 5 years ago, you could still order the rubber gasket for the tool tray. I used storm door insulation for glueing and put clothes pins all around and let the glue set overnight. I still have to reposition the tail end of the gasket now and again (just like the original) when I open the seat.
    Virginia Beach
    current:14 R1200RT 75 R60/6
    "Goop everywhere" seems a 'merikun tradition but has no place on BMWs.
    Don't use adhesive/sealant except where BMW specifies.
    Gluing on gaskets is NOT universal practice.
    Sep 2004
    Arlington, TX
    glue
    These gaskets came with glue on them. Just so ya know.
    Boxerbruce
    Oct 2009
    Northern Cal
    3 spots of Crazy Glue work great on the seal. One on either side of the drain and one above that right in the middle.
    www.boxermetal.com
