Results 16 to 26 of 26
Thread: booster plug installation r1200r
    'Forgiven'
    Feb 2011
    SW Montana
    Quote Originally Posted by BinkleyLane View Post
    Hey Pipestone,
    Where do you have the termistor ( temp sensor ) placed. I see it in the pic, is that where you leave it?
    Right in here..
    Dana
    God Bless America
    2011RT "Favor"of God
    Sep 2011
    Weston, Tx
    Pipestone, so what do you notice in performance on your 2011 RT. I have been thinking about doing this but what improvements do you actually notice?
    BinkleyLane binkleylane's Avatar
    Jul 2012
    Springboro, OH
    Quote Originally Posted by pipestone View Post
    Right in here..
    The perfect spot! Now I will have to pull the Tupperware.
    B-est M-otorcycle (in the) W-orld
    Have Bike - Will Ride
    mattituck new york
    any problem with stickin' the BP temp sensor here?
    put about 25 miles on it today... temp about 60 degrees. can't really say i notice much of a difference. might have been a bit smoother off the line and at slow speed in second and third. i did notice a definete aroma during idle warm up... probably unburned fuel due to the richer f/a ratio.
    'Forgiven'
    Feb 2011
    SW Montana
    Its just what everybody says it is..for me a big A+ in all around drive ability..I run a Remus exhaust w/baffle in.
    I'm a very happy customer
    If you don't like it ..which I doubt..unplug it and sell.
    I read like you once about this product..best upgrade I made to the RT
    Just what I think
    Dana
    God Bless America
    Sep 2011
    Weston, Tx
    Thanks for the input. I think I will pick one up. I too have a 2011 RT so was interested in what you thought. Instead of a Remus I have an Akrapovic that I have taken the baffles out. I will let you know what I think of it.
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by f14rio View Post
    In answer to the Q in your title, possibly -- if I read that photo correctly, you have the BP air temp sensor just in front of/above the rear fender. Most times I would believe this to be ok, but when stationary the heat from the catalytic converter might cause false high readings.
    If I get one of these for my '12 RT, I'll have the sensor in the intake air path somewhere (I have to say, putting it into the back of the airbox above is a quite slick idea!).
    Mark Neblett
    Fairfax, VA
    #32806
    mattituck new york
    thanks
    i doubt that moving it around would change things much. i dunno
    Feb 2007
    Central NJ
    I have a BP installed on my R with the temp sensor zip tied to the left side of the fuel canister.It's in clean air all the time.
    I have the same performance results as you do..... better idle..... take off at lower RPMs but other than that no real noticeable difference.
    Marty
    O6 RT, 03 F650GS
    Dick Bush 167702's Avatar
    Feb 2011
    Pocono's Pennsylvania/ Ft Lauderdale Fl
    Talking Love the booster plug
    I have had the booster plug installed for about five days now. It took 15 minutes to put in and I am so pleased with the results. A+++ I have an R1200 gs and it had made a big difference. I read on a lot of different forums about mpg's to be frank i would sacrifice 3-5 mpg's for what this simple plug has done
  11. #26
    On the Road
    NC
    IAT Sensor
    Where can you buy the IAT sensor and what is the usual price?
