Results 1 to 12 of 12
Thread: installed a booster plug in my 2010 r1200r
    mattituck new york
    i don't think it can be wired incorrectly.
    anyway, the bike starts but won't idle without crapping out. i gotta keep goosing it like a harley guy. 70 degree day, first start of the day for the bike. not permenantly installed (obviously) i doubt the engine got warm enough to affect the temp sensor which was hanging down below the bike.
    might hafta send it back.
    anybody have a similar thing happen?
    thx,
    ed
    Talking
    There is a bunch of stuff on the R1200r forum.
    It may need a TPS relearn.
    Unhook battery
    Hook up battery.
    Turn key on turn throttle 2 or three times from closed to all the way open. Turn key off.
    Start bike like normal.
    Please let me know if that does it.
    David
    Nov 2005
    Fairfax, VA
    You are not supposed to hook up the BoosterPlug to the fuel injectors.
    Plug the unit in between the air temp sensor and the bike harness at the sensor(at the airbox).
    Mark Neblett
    Fairfax, VA
    #32806
    Quote Originally Posted by mneblett View Post
    Good eye!
    mattituck new york
    will check tomorrow
    so it is possible to plug into the wrong connector?
    they must obviously be the same part no.
    sent you a PM...
    Steve Henson
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by f14rio View Post
    Yep, the air temp sensor and the fuel injectors use the same spring-latched connector.
    Mark Neblett
    Fairfax, VA
    #32806
    mattituck new york
    thanks and as henzilla pm'd me...
    .. i need to learn to read directions.
    thanks again, henzilla
    ed
    Jul 2007
    THE BIG SKY
    There is a reason you flew in them and didn't maintain them.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    mattituck new york
    re: "There is a reason you flew in them and didn't maintain them."
    you got that right., AK.
    'Forgiven'
    Feb 2011
    SW Montana
    Please post back after you get it going and let everyone know what you think
    Dana
    God Bless America
    2011RT "Favor"of God
    Forums are great!
