Results 1 to 7 of 7
Thread: 1989 - 1995 model year diferences
    Nick Kennedy
    Telluride Colorado
    Hi Gents
    Shopping for late model R100 RT airhead...
    Question: Are there any major or minor differences in the years of 1989 - 1995 manufacture of the R100 RT ?
    Thanks In Advance
    Nick Kennedy
    Oct 2009
    Northern Cal
    There is only one I am aware of. In 91 they went from 13mm to a 14mm master cylinder.
    www.boxermetal.com
    www.facebook.com/boxermetal
    A true '95 should have the circlip on the transmission input shaft.
    Things that come to mind are minor. Slightly different seat cushion shape over the years. Later models often have the Integral type side cases (sometimes see the older City cases on the Integral mounting frames as well), the Ignition Control Unit bonded to its heat-sink, silver wheel finish (vs. black), Valeo (vs. Bosch) starter, and 14mm master cylinder as mentioned (vs. 13mm). Most of the later model "upgrades" kicked in late in the 1989 model year. Around the 1995 model year the transmission regained the infamous "circlip", but quite when seems to be shrouded in mystery. Probably some other details as well.
    Mark
    Current ~ '74 TR5T : '93 R100R : '99 Gran Canyon : '06 ST3s
    Past ~ Variety of British, French, Italian, Czechoslovakian, & German bikes
    Aug 2004
    Walnut Creek, CA
    There's some minor differences in the main electrical harness. In 1/91 the wiring harness was changed from the older fuse type to the blade type. I believe they separated the electrical system into three fused circuits instead of two. I would not let this be a deciding factor. In fact, the later harness will fit on the earlier bikes. However, neither harness is available from BMW. They are NLA.
    Jeff in W.C.
    Nick Kennedy
    Telluride Colorado
    Thanks guys, for the advice, once again.
    As I'm sure you've seen there have been a couple of real sweet looking machines come up for sale this summer/fall.
    Cheers
    Nick Kennedy
    Hopelessly lost subagon's Avatar
    Plant City, FL
    Quote Originally Posted by nickrides View Post
    Cheers
    Nick Kennedy
    How true! I'm flying out Tuesday to pick up a '94 RT and riding it to it's new home.
    Mike Barfield - Plant City, FL
    '07 R1200 GS - '75 R90/6 - '93 R100GS PD - '71 R60/5 - 2 X '73 R75/5 LWB - '83 R80 ST
    Picts
