Results 1 to 15 of 24
Thread: R75/5 H4 headlight?
Hybrid View
    stucknarut
    R75/5 H4 headlight?
    The project bike I'm working on came with a great big vetter fairing, which I've removed. I'm left with no front headlight or chrome ring. Is there an H4 kit complete with lens and chrome ring that won't break the bank? Needing something fairly quickly so if it could be sourced locally that would be ideal.
    On the Road
    Dec 2010
    Cromwell CT
    Ebay is your good friend. I was on the same bout as you are 2 years ago, and I believe it would be around $100~150 range.
    I have heard!!!
    I have heard but not tried it myself that R 65 any year guts, lens, reflector and chrome ring fit and work.
    stucknarut
    Quote Originally Posted by 69zeff65 View Post
    There's one of those on ebay right now...can someone confirm that? Size seems to be similar.
    /5 H4 conversion
    /6 parts will not work. You need parts from a 80's R65 or R80ST or R80GS.
    You need bulb, reflector, lens, lens gasket,clips and chrome ring.
    Try: bmwhuckys.com , bemmer boneyard, Bobs BMW etc. and e-bay of course.
    Good Luck
    The Lonerider
    Pismo Beach, CA
    If you order from Hucky you need to be aware that he offers two versions of H4.
    One is OEM, with metal reflector.
    The other (below) has a plastic reflector and bonded-in glass lens and it has a "park" lamp; $115. It is a bit of a loose fit in the head light ring so order extra headlight clips (3 is standard issue (none are included)) I bought this one and it seems to be holding up okay. One thing about I do not care for is that the plastic reflector shell allows some light to enter the inside of the head light nacelle which illuminates the turn signal bezel. Not as brightly as when the turn signal is "on", but enough that it is noticeable (and a bit annoying) after dark.
    They both use the "standard" H4 bulb.
    Another $52 gets you the ring
    And another $11 gets you three clips
    Out the door with shipping, somewhere near $200 vs. $450.
    Disclaimer: I'm not affiliated with Hucky's in any way.
    Here's what it looks like installed.
    Lew Morris
    1973 R75/5 - original owner
    Wisconsin and Florida
    I can confirm that the headlight ring, reflector with H4 bulb from 1980 R65
    does fit and function properly on 1971 R75/5
    The chrome ring from the R65 has a little different look - not so smoothly rounded
    but fits just fine - in fact better than the original R75/5 because of the screw retainer
    system at the bottom on the R65 instead of just the press on tang
    I had these two bikes parked next to each other and did the switch after reading this post
    Had been thinking of trying it anyway since the R65 is a dead duck and the R75 is good
    Oct 2009
    Northern Cal
    The PO of my R60/5 stuck an H4 in the stock reflector. It takes a little fussing to get it to sit straight and seam to work fine. The next best thing would be to replace the lens with one from 79-84 R65.
    www.boxermetal.com
    www.facebook.com/boxermetal
    The original post indicates what is needed is ring, reflector and bulb because these parts
    were lost when Vetter fairing was installed
    So in my opinion if only good function and not show correctness is desired he should buy
    a ring, reflector and bulb for R65 rather than the parts needed to convert the /5 to H4
    The R65 part is superior in function due to screw retainer at bottom and probably cut/focus of the
    glass
    Forgot to mention that if you use the R65 light and want the parking lamp to work you will also
    need the parking lamp holder from the R65 also
    Oct 2009
    Northern Cal
    Quote Originally Posted by 44006 View Post
    glass
    Those parts new from BMW are over $500.00. I would go with the aftermarket ones.
    www.boxermetal.com
    stucknarut
    Thanks for all the advice. I neglected to mention, I'm also on something of a tight schedule, as I would like to ride the bike to Barber next week. Ebay is out since nothing available within that timeframe. I was able to find a loaner /5 lens, ring, and reflector nearby which will do for now. I'd still like to go H4 in future; maybe I'll shop my way around the swap meet next week.
