Results 1 to 3 of 3
Thread: K12RS v K12LT gearing
    1960R100S 1961BMWR69S's Avatar
    Mar 2009
    Crown Point IN.
    I have a ?..... I have a 02 K12RS with a 33/12 rear drive. A guy in my motorcycle club gave to me a brand new rear drive unit from his 09 K12lt witch is a 34/13 ( he tricked it ). Would the LT be a lower gear or a higher gear then the RS gear.
    Astatula, FL
    33/12 = 2.75
    34/13 = 2.62
    The LT gearset will cruise at 60mph at a few lower RPM than the RS gearset. Your acceleration will be slightly slower.
    Bob Weis
    '04 K12RS - Hannigan Hack
    #13338 PGlaves's Avatar
    Quote Originally Posted by Bobmws View Post
    33/12 = 2.75
    34/13 = 2.62
    That is a 4.72% change in ratio. So whatever the stock gearing has the engine turning at any given speed will be reduced by 4.72% at any road speed, in the same gear.
    So, for example, if with the original gearing the engine was turning at 4,000 it would be turning be turning at 3,811 with the new gearing
