Results 1 to 9 of 9
Thread: replacement front disc for 74 R90/6
    Registered User mrabiff's Avatar
    Jan 2012
    Missouri
    Question replacement front disc for 74 R90/6
    I would like to replace the front disk on my 74 R90/6 with a drilled disc. Any thoughts on where to get the best deal on one? Also, any thoughts on making this change?
    Mark
    Land of OZ
    Monza Blue 1974 R90/6
    Delaware
    I replaced my original cast (no holes) rotor. Although stopping power was ok and it (and the pads) was within spec, I had suffered for a long time with a squeal that I couldn't get rid of.
    I replaced it with with an EBC drilled disc and at the same time put on new EBC pads. I thought the EBC price was good value. Works great. No squeal. You'll have to get used to a a "new" sound from the drilled rotor.
    Spiegler is another source. They will modify your rotor to a floating design. I considered this, but ultimately went with EBC.
    Lots of feedback in this forum on options.
    Barron
    Jan 2012
    Missouri
    Thanks for the info Barron.
    Jun 2007
    Minneapolis, MN
    I put floating EBC's on my K75 and Spiegler floaters on my R65LS.
    Hands down: Spiegler is much better.
    Not sure Spiegler is the best deal but I don't compromise with brakes!
    Good luck!
    palica
    Grimeca discs are on sales at Motobins in October.
    May 2012
    VA
    Maybe it is a waste of time and money, but I am also trying to get better brakes out of my /7, which has the same brakes as the /6. Perhaps it's a lost cause and I am just being stubborn. But, EBC pro-lite rotors and pads are my next step.
    The EBC pro-lite rotors MD602LS and pads FA22 are readily shipped in the US and are a bolt on switch. This website seems to have the best price I have found, www.oemcycle.com (@ $200). I actually ordered these from denniskirk.com when violating one of my tenants of online ordering and paid a bit more, but I am pleased because life lessons can be harder. Best of luck in your pursuit of better brakes!
    Stan
    AH# 13238
    Houston, TX or Portland, OR
    Quote Originally Posted by Stan_R80/7 View Post
    I did this as well, along with upgrading to dual discs from a single disc. The dual disc upgrade (using stock BMW rotors) yielded much more outright stopping power, but then switching to the floating rotors was yet another step better (smoother braking action, translating to better stopping performance). The brakes on my bike are so much better now than at any point over the preceding 20 years, it's almost unbelievable!
    Jim
    '90 and '93 Mazda Miatas (Jelly Bean and Red Hot), '02 325ci (Blue Streak)
    Jul 2006
    Are you endorsing oemcycle?
    Have you used them before?
    I need to replace my rotors this winter and was wondering what the best replacement was currently.
    What are your tenants of online ordering?
    May 2012
    VA
    Quote Originally Posted by wuzred View Post
    I am not endorsing - or not endorsing - any vendor as such, just stating the facts from my perspective and results from an internet search using Google. There are many factors that are part of 'value' when buying.
    I cannot answer - nor do I choose to try and answer- what is the best replacement. I do not know what is the best replacement based on your needs, wants, goals, or budget. However, I do know the OEM BMW rotors are specified by BMW.
    One of my primary tenants when ordering online is to get some sleep before making any purchase. Avoiding impulse buying is the main benefit from that practice.
    Stan
    AH# 13238
