Results 1 to 15 of 21
Thread: R1200GS Oil Change
    Apr 2009
    Cincinnati, Ohio
    R1200GS Oil Change
    Have done it before, but not immediately after having changed oil on a car.
    The contrast is pretty funny.
    Car - One socket for the oil plug. Removed the filter by hand.
    R1200GS - Three different sockets needed just to get the skid plate off. Then, a mail hex socket needed to get the plug out. Then, a special tool I had to buy - can't remember when, from whom, and for how much - to get the oil filter off.
    Oh, and you need a tool to get the filler cap off so that you can refill with new oil.
    Right now I feel like I own a 1970s MG.
    But the bike sure is awesome to ride. I'll give it that.
    2009 R1200GS
    atlanta
    Yes, I've always thought cars were too easy. No time to bond.
    Marty Hill
    12 GS black/7 GS white
    ride till you can't
    Albuquerque, NM
    Plus, you had to use a new crush washer when reinstalling the drain plug.
    You have to do this, too, on German cars, but it's now mostly irrelevant as they're all designed to have the oil vacuumed out via the dipstick tube.
    Kent Christensen
    21482
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    "Removed filter by hand" Really? I've never owned a car that didn't require a filter wrench of some sort.
    The GS has pretty much everything you need in the toolkit except for the filter wrench. I don't have to put the GS up on ramps to get under it to remove the filter and drain plug. My GS is far simpler to change the oil than any of the cars I've owned. But, I do think BMW could have given just a little more thought to the nuts and bolts on the skidplate Technically the skidplate is probably optional for the 90% of GS riders that never leave the pavement.
    Neal - '09 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Apr 2009
    Cincinnati, Ohio
    I only take the filter off by hand when I am under there and have forgotten to bring the wrench with me.
    Sure would like to do work on my bike beyond just changing the oil, like a lot of you guys do, but I am just plain chicken. I have no fear tearing my car/truck/boat apart, but maybe because I love my bike so much I am afraid to break it.
    2009 R1200GS
    Mar 2008
    Camas Valley Oregon
    Get over it, get into it. You'll love it.
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
    I'm doing a clutch spline lube and also complete major service on my R1150R, plus all those other little things encountered while doing all of that. Oil change? Not so bad.
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    I have the BMW large skidplate on my and it is 6 bolts, but all the same size so that helps. And on my truck it always seems to need a wrench on the oil filter partially because it is so hard to get a hand on it. So that is a wash. Upside to the bike is I don't have to lie on my back to do the work.
    Truck oil change is faster though, but I don't find the GS to be that bad.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA
    RROOKEY rrookey's Avatar
    Jul 2012
    Ellington, CT
    Quote Originally Posted by MPMARTY View Post
    Ditto
    Apr 2009
    Cincinnati, Ohio
    And darn it that I think I overfilled the BMW.
    The car I changed first is my wife's Saab 9-5 wagon, which has a high-pressure turbo that allows for 260 HP out of a 2.3 liter 4 banger. That car eats a quart every few thousand miles and my frame of mind was "more rather than less".
    My 1200GS uses almost no oil, and I tried to put in the full "4.1L" stated in the manual. That came out by my crude methods to be 4 quarts plus around 5 ounces of quart number 5. The level is now such that the oil level is above the site glass.
    All in all though, I'm sure the big GS can handle it and all will be okay...
    2009 R1200GS
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Special tool for the filter? Really? It's been a couple of years since I had a hexhead GS, but as I recall, I was able to use a good old strap-type filter wrench. There was a trick to it, as the exhaust or something played interference, but if I jiggled it just right I could get it onto the filter and get just enough motion to do the trick.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Did that last time. 4 qts and 4 ounces. Over the check window for 1,000 miles . Its finally down to the top of the window cold.
    My 1100 would be at the bottom of the window by the 1,000 miles.
    Next change 4 quarts with a BMW filter.
    Apr 2009
    Cincinnati, Ohio
    Yes. Last time I did 4 quarts plus empty filter. Level was just barely to the top of the glass. Had a brain cramp this time.
    2009 R1200GS
    Quote Originally Posted by The_Veg View Post
    Not special, just different than the tool many used on the earlier bikes. The number of flats on the filter changed. Some tools, like your strap wrench, will work on either filter.
    Mar 2008
    DeLand Florida
    I just did the first DIY oil change on my R12R. The last change was during the 600 mile service. I have never had a bike that had the filter on as tight as this. I do not know if it was installed dry or not, but I barely got it off even with the proper wrench. Maybe super glue was used on the gasket instead of oil. Other than that, a simple job and only took 10 minutes.
