Results 16 to 30 of 32
Thread: best jacket for the fall and winter
    Registered User arptra's Avatar
    Feb 2006
    Dallas Texas
    thanks for all of the input, i ordered a firstgear catmandu and i will see how it is.
    Alan,,
    Dallas Texas
    74 R90S, 76 R90S, 95 R100GSPD, 08 R1200GSA
    vancouver ,wa
    Thumbs up
    It is spelled Kathmandu , they run on the large size.
    Mar 2007
    Chicago, Ill
    Fleabay
    If used will do - and it does for me - check fleabay and the gear sections here - Used jackets can be had for a song.
    +1 on 3/4 length, windstopping lining and electric warming. I wear a Darien jacket or a Roadcrafter with an electric jacket liner - I'm good down to 20 degrees or so.
    www.hivizstore.com hivizguy's Avatar
    Pittsburgh Area
    Kilimanjaro Jkt
    I've been using a Firstgear Kiliminjaro Jacket this year, in Hi Viz of course. It's been working out quite well. Windproof, waterproof, and slightly insulated. Come Winter, I've added a fleece underneath and have making due pretty well.
    For the past 3 years before I was using the overlooked Scorpion Commander Jacket. Scorpion is known for their helmets and street styles, however if ever there was a jacket I was going to wear on my ride to, let's say, the moon it would have to be the Commander. They've just re-styled the jacket for 2012. It features an outer Lining (not waterproof) followed by Windproof / Waterproof Liner, with an inside thermal vest, and topped off by a storm collar. I haven't tried out the new jacket yet, but am wondering if they have made the outer shell a bit more waterproof.
    Last but not least, when buying a jacket, don't forget the visibility. After all I like to say, "If they see you, they might not run you over as bad."
    Good luck with the purchase, I don't think you will be let down with the Firstgear.
    Be Seen and Be Safe,
    Hi Viz Guy
    Be Seen and Be Safe
  5. 12-28-2012, 05:38 PM
  6. #20
    Sep 2010
    Hiawassee, GA
    Silly question
    I just got a Hi Viz Katmandu for Christmas and love it. I wear it over my heated liner from Powerlet. Now, here is the silly question. If its waterproof is it also windproof? The reason I ask is that my arms still feel a little cool even though the line has wires in the sleeves. Should I also be putting a windproof shell over the liner?
    I must say I enjoyed riding yesterday with the little snow flake blinking on my dashboard.
    Mary
    2007 R1200RT, gone
    2009 R1200RT, gone
    2014 R1200RTW, GREAT
  7. #21
    Kbiker BCKRider's Avatar
    Jan 2009
    B.C. Canada
    Quote Originally Posted by Elgin Mary View Post
    Can't answer your Katmandu question about waterproof being windproof, though I think it should. What I CAN tell you is that there are a lot of jackets like my Rev'it Sand that come with a rainproof zip-in liner. Translated, that means the outer jacket will absorb A LOT of water in heavy rain (unless you find exactly the right washing then treatment products,) though if you do everything right you will stay dry. These jackets with the rain liner in and electric jacket (with a controller) are great for staying comfortable from temps above 50 to below freezing. No disrobing to add or subtract inner garments - which is why I think all insulated non-electric liners suck. They will be perfect at only one temperature. Temperatures can vary considerably on even a few hour ride and it is great to dial in a little more or less heat as needed. For light rain (or snow) these jackets are great. Also fine if you will be coming home and the jacket can hang a couple days to dry out after a heavy rain.
    In the summer on trips, I skip the rain liner and replace it with an outer rain jacket - which is easier to don or shed in summer showers. Mostly take the electric jacket though. (If you are thinking of buying one, take a look in this forum at the problems people have been having with Gerbings of late.)
    Doug
    1992 K100RS
  8. #22
    Aug 2012
    I have a Rev-it also. I think it is the Dragon model. I wanted something shorter and lighter, but this has been a great jacket for fall and winter.
    The bottom line, I like it. I would purchase again.
    Lynn
    MOA #57883
  9. #23
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    I presently have a couple of setups I use:
    Motoport Airmesh II kevlar jacket and pants
    Olympia hi-vis yellow/orange.
    Both are excellent in hot weather we have in south Louisiana. For cold weather, both jackets have waterproof and insulated layers zipped in.
    As noted in other posts, the insulation liners can get cold or hot when riding if you are not in the temp range of the insulation. I have never used the thermal liners in either jacket, mostly to avoid the "Michelin Man" stuffed effect.
    When the temps get below 60, I put in the rain liners, and below 50 the Warm-n-Safe electric liner goes in. This setup is functional until the temp drops into the mid 40's when the windchill, when riding over about 30 minutes, will begin to cold-soak the mesh and the rain liner, and the electrics cannot quite keep up with the heat loss. Around 45, I usually put on my external rain gear to add another wind block layer and give about a 1 inch airspace over the electrics. This setup has been used into the low teens and I am quite comfortable when the electric liner is about 2/3 full on. Even my cold natured wife is "Warm-n-Safe" and I have no complaints in the intercom. She also has electric gloves, pants and sock inserts and is a very happy camper.
    One thing to remember about underwear : NO COTTON !. Cotton can kill in cold weather because it stays wet, and we all know about monkey butt in hot weather. I only use wicking stuff, mostly CoolMax or similar.
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288, Board Member, Divers Alert Network
  10. #24
    Jan 2012
    Stamford, Ct.
    tour master my choice
    I bought th tour master Seirra jacket last year at the NYC MC show for $165. Great jacket, lots of pockets, 2 liners, one that is insulated, the other wind, waterproof. You can wear one or both. On the cold days here in the NE, I also wear ski long johns and a thick wool sweater. I stay nice and warm, though I looking at heated jackets. The tour master has been great for me. Just find the best fit for the best price.
  11. #25
    Registered User tgolder151754's Avatar
    Jul 2009
    Cochranville PA
    I started researching a new jacket about a month ago and here's what I found along the way. I started by stopping by the Revzilla store for a couple hours of trying on just about everything they had. They had Dainese, Olympia, Alpinestar, Rukka and Klim. All great jackets but I just didn't like the fit on most of them. The Klim was close but I'm in between a medium and a large. The medium was just a touch tight in the arm pits and the large sleaves covered my hands completely???
    A few weeks later I stopped by Bob's BMW to go through their jackets. Mostly the BMW brand and Revit. There's something about the Revit gear that I just don't like. My wife wears one and there's just a lot going on with the liners. One liner for warmth, one for rain, etc. They fit pretty well but I just never got a warm and fuzzy feeling.
    I tried the new Tourshell, Rally 3 and Streetguard 3. Having the ability to try on a 42, 44 and 46 was wonderful and filled the gap between a medium and a large. All of the jackets fit great in a 44 but I kept going back to the new Tourshell. It has a waterproof shell....not a liner. It's very understated in it's appearance but provides very good armor that feels like it will stay in place if needed. The Rally was my second choice, followed by the Streetguard. Even when removing price from the equation I'd still lean in the same direction.
    2009 R1200GS
    2008 Suzuki Vstrom
    2005 Honda ST1300
    1988 BMW K75S
  12. #26
    Registered User kurtnocal's Avatar
    Sep 2012
    Tourmaster Transitions 3.0-Good Value
    We bought Tourmasters (my wife and I) and have been very happy. The model is a Transitions 3.0. It has a removable liner for when it warms up a bit. We live in Northern California and this jacket keeps me warm down to about 45 degrees with the liner in. Colder than that I put on the Gerbings. Very wind proof. I can't attest to the waterproof qualities, because I refuse to ride in heavy rain, but no issues in mist at all. If you are concerned with rain, any quality manufacturer such as Klim, or the Beemer stuff with Gortex would be best. Like I said though, very happy with the quality of my Tourmaster and though I don't remember what I paid for it at Cyclegear, I remember it was very reasonable, around the $130 range. Good luck and let us know what you selected.
    2013 F700 GS
    Ostra Metallic Gray
    A boy lies in the grass unmoving staring at the sky...
  13. #27
    BMW Pilot runnr548's Avatar
    Feb 2012
    The Atomic City
    Cool
    I have First Gear's KATHMANDU (last years style) and it is awesome! It has many pockets...vents...great zippers...etc... I also got their pants to go along with the jacket. It is a GREAT combo!
    http://www.firstgear-usa.com/kat.html
  14. #28
    Registered User lionheart33's Avatar
    Nov 2006
    I have a Hi-viz yellow Moab jacket from Olympia - it will be two years in April. It is a mesh shell and has one water-proof liner and one Thinsulate liner. I wear it all year in North Carolina. In the summer with no liner up to 100+ degrees. In the Spring/Fall with the water-proof liner from about 50 to 70 degrees - it is also like a windbreaker. In the winter with both liners from as low as 20 degrees - my core does not get cold but I will also wear a good thin Nike/Under Armor/polypropylene layer when it is below freezing. the jacket is adjustable and fits well with or without the liners. The Hi-viz color makes a difference, drivers tend to give me more space. I don't like the pocket arrangement and I think it is a one and done jacket, but other than that it is an excellent jacket.
  15. #29
    RideTN RideTN's Avatar
    Apr 2012
    W TN
    http://www.aerostich.com/jackets-pan...le-jacket.html
    excellent cold, wet weather riding choice. mine has served me well.
    RideTN
    W Tenn
    2012 r1200rt
  16. #30
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    Quote Originally Posted by arptra View Post
    does any one have suggestions on a good riding jacket mainly for cold weather, I have a mesh jacket for summer. I have been looking at first gear but they have about 4-5 different styles available, I'm mainly I would just like to stay warm.
    If you filled out your profile or gave just a tad more info you might narrow things down a bit. Cold weather to a rider in Tampa Bay means tee-shirt weather to a Vermonter. My ride today was warm at 26F with light snow.
    '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan dual sport sidecar for rides with Tulliver
