Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 61 to 75 of 80
Thread: Need Oil
  1. #61
    Northern Front Range, CO
    Quote Originally Posted by ka5ysy View Post
    BULLETIN ! : SG is now an obsolete rating. Current ones are SJ/SL/SM/SN
    Go to the American Petroleum Institute site and get the ratings guide, use the current standard, and stop stressing over oil ratings. For those still worrying about thin oil and what temperatures are used with what viscosity rating, the bottom of the last page in the PDF file noted below shows the temperature ranges recommendations. PDF file is here:
    http://www.api.org/certifications/en...010_120210.pdf
    Now go ride and quit wasting bandwidth, time and oxygen worrying about oil.
    why would we want to use the current API rated oil when it's specs do not fully meet our engine's requirements for ZDDP and other additives?
    SG is still readily available & meets specs as delineated by the manufacturer? again- newer is not necessarily better.
    Ride Safe, Ride Lots
  2. #62
    RAINEY 187132's Avatar
    Sep 2012
    Grand Rapids, MI
    Quote Originally Posted by Gilly View Post
    And once the SG oil is no longer produced, than what do you do?
    As oils advance the are typically backwards compatible. Which means they meet and exceed the previous specification and can be used in place of without voiding your warranty.
    However, this is not always true with Automatic Transmission Fluids.
    Jason
    Grand rapids, MI
    2012 BMW R1200RT
  3. #63
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    OK here is the REAL truth. When you can no longer get SG rated oils, your bike will implode and melt into an unrecognizable lump of aluminum, steel, copper,magnesium, rubber and plastic, bubble a bit and then reach critical mass and cause a low yield nuclear explosion that will destroy everything within a three mile radius. BEWARE OF USING THE WRONG OIL. OMG !
    Oh... and then EPA will send you a bill for the mess you made !
    Doug, 2011 R1200RT Polar Metallic
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288, Board Member, Divers Alert Network
  4. #64
    On the Road
    Apr 2012
    NH, USA
    Ah, the never ending oil/lubrication debate. What would we do without it?
  5. #65
    Oct 2006
    Quote Originally Posted by rut3556 View Post
    Indeed !
    Semper Fi, by the way ...
  6. #66
    Jul 2007
    THE BIG SKY
    Lightbulb
    Are we sure oil is absolutely necessary?
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  7. #67
    Oct 2006
    Quote Originally Posted by AKBeemer View Post
    According to Al Gore, NO !
  8. #68
    Apr 2006
    sooo............just sell it to me now, and save the agony......................... for scrap prices of course
  9. #69
    Sep 2006
    Quote Originally Posted by RAINEY View Post
    Nor brake fluids
    Steve Henson
  10. #70
    Jul 2007
    Evansville, WI
    OH, OK, that fixes THAT problem then.........
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
  11. #71
    Oil is good.
    Some oil is good.
    No oil is very very bad.
  12. #72
    Jul 2007
    Evansville, WI
    Quote Originally Posted by scott.lambert View Post
    Some oil is good.
    Most. Useful. First. Post. EVER!
    (and welcome to the club, Scott)
    13 C650GT
    MOA 44606
  13. #73
    Oct 2006
    Hi Scott ! Welcome to the asylum
  14. #74
    A number of European and Asian car makers now ignore the API specs and use the Japanese or European rating systems altogether. The reason is that in some respects the later API specs are not as good as the earlier specs. This is particularly true when it comes to the anti-wear additives. BMW said so regarding their motorcycles when the API went from SH to SJ years ago.
    But folks still argue the point on their keyboards even today. Just because the API, under pressure to reduce ZDDP says that a later rating "supercedes" earlier ratings does not mean it is superior in all important respects. I use SG rated oil.
  15. #75
    May 2011
    South Kentucky
    I like to see these specs on oil I use on my bike
    Meets or Exceeds API SF/SG/SJ
    Meets or Exceeds JASO MA2
    Anthony S.
    2012 R1200GS
