Results 1 to 11 of 11
Thread: 2007 R1200GS Won't start
    Nov 2011
    Buena Vista, Colorado
    Need some advice on a non-starting GS. Turns over fine and it is getting spark but won't run. Maybe a fuel pump? Had been running fine up to this point. I would appreciate some advice on this one.
    Northern Front Range, CO
    I got nothing for you, except............you'll get better advice about your HEXhead if you post your questions about it in the correct sub-forum.
    Mods- clean up on Aisle O!
    Ride Safe, Ride Lots
    Nov 2011
    Woops. Sorry about the wrong forum
    Nov 2011
    2007 R1200GS won't start
    My GS will turn over but not run. Has spark. I have read about the EWS ring failure. Any ideas
    Mark
    I don't think it will crank with an EWS failure.
    I suspect a fuel pump issue. Listen to see if the puel pump comes on when the key is turned on.
    Registered User f14rio's Avatar
    mattituck new york
    fuel, air, spark
    ntxt
    "Enemy fighters at 2 o'clock!...Roger, What should i do until then?"
    2010 r1200r, 2009 harley crossbones, 2008 triumph/sidecar, 1970 norton commando 750
    Nov 2011
    Fuel pump is coming on
    btw- if you're thinking fuel pump, listen to hear it initiate at start up; you should hear it pressurize the FI system during the first 5 seconds or so after you turn the key on (with sidestand up and/or in neutral).
    Mar 2008
    Camas Valley Oregon
    Or pull an injector and point it into a can and crank engine. No spray = fuel pump or its controller.
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
    Quote Originally Posted by MPMARTY View Post
    Or Motronic or its connections.
    Nov 2011
    Fixed 2007 GS no start
    Replaced fuel pump controller and all is well.
