Results 1 to 13 of 13
Thread: 1994 K75, center stand, side stand lube
    Off looking at yet another potential 4th Gen 4Runner I noticed a Harbor Freight tool store across the way. I stopped in and was handed a load of coupons by someone leaving, including ones for $10 torque wrench and $10 lever grease gun. Walked out with those two and an assortment of other things I sort of need
    I stopped and got a tube of synthetic grease and this morning attacked the side and center stand. Well, it took all of 30 seconds. There are three zerk fittings I could see, one on the side stand and two for the center. Couple pumps on each, just until the grease starts squeeging out. It had not been done in a while, certainly not since I have owned it, and is easily overlooked. The early k bikes did not have zerks so check yours before proceeding.
    Ted
    1994 K75RT
    Moto Pages
    RK Ryder
    London, Ontario
    My '87 K has these grease nipples which making lubricating the stands an easy task. Why did BMW not do that with the stands on my '98 R1100 (as well as not including the K self-cancelling turn signals?.
    Paul
    Knights of the Roundel #333
    Apr 2007
    Rockport, TX
    While my '94 also has the zerks installed mine were too gunked up or dried out to take any grease---I installed new zerks and now it's a breeze to lube the stands.
    Thanks for posting this reminder; preventive maintenance never hurts (except in one's pocketbook sometimes).
    ---Jeff
    Some models have a small conical recess machined into the stand(s) that take a pointed grease gun fitting instead of a traditional zerk.
    On some models you are supposed to take the bolt(s) out and grease things. Duh!
    On these I just dribble in/on oil instead of using grease.
    Registered User jwetering's Avatar
    Aug 2011
    north vancouver
    I wish I had grease nipples ( not *greasy* nipples - c'mon!). My 1990 K75 just has the conical recesses and it's awkward to get the lube in there to say the least.
    I suppose this winter I could take it all apart, drill and tap some holes where the conical depressions are an install some "zerks" as you call them. That sounds like a fun little project.
    Lord knows both my stands could stand a bit of lube.
    jasper
    north vancouver
    1990 K75S
    Belton Tx
    I spray lithium white grease into the conical thingys on my 91 75RT.
    Ron
    91 K75RT ABS
    Quote Originally Posted by jwetering View Post
    or, just buy the pointed grease fitting that PaulG mentioned.
    Paul,
    BMW made a lot of things worse when they introduced the R1100s. Not only didn't they get self-cancelling turn signals, but the horns became a joke, too. The tool kits seemed flimsier, and when you wanted to get at on the side of the road, you had the pleasure of dropping your seat onto the dirt because they no longer flipped up.
    Quote Originally Posted by tonycarlos View Post
    Paul,
    True, but they also made a lot of things better. That droppable seat was 3-way addjustable on the RS. The handlebars were adjustable both for and aft, and angular. The windshield was also adjustable by turning a knob. No fuse to blow - no motor to stick.
    ...and, some models, like the R11S, retained the self-cancelling turn signals.
    Tony- i would say that all your gripes are valid (in that those issues could have/should have been addressed), but relatively minor in tehir significance.
    overall, the oilheads as a complete bike were light years ahead of the airheads that they replaced (better brakes, better suspension, better handling, better motor performance, etc.). and, they offered a nice alternative to the K-bikes.
    Jun 2012
    Olympia, WA
    For stands with the conical holes, I have found that this inexpensive small Harbor Freight Grease Gun fits perfectly.
    May 2004
    boise, idaho
    lubing side/center stands
    What some of us need are self-tapping zerk fittings!
    RK Ryder
    London, Ontario
    Quote Originally Posted by walt3022 View Post
    Paul
