Results 1 to 7 of 7
Thread: lube mix
    Registered User KARSTEN's Avatar
    Jun 2004
    Mobile,Al.
    lube mix
    planning on lubing the spline on my 1999 R1100,been reading a while back that people use a mix of honda moly paste with another grease. Cant find where I read it, what is the other part of the mix?
    thanks in advance
    The two greases I have mixed are Honda Moly 60 and Wurth Sig 3000 grease.
    Wurth Sig 3000 is a very thick, very sticky, green grease. It can be a bit hard to find. It is available here:
    http://www.mgcycle.com/product_info....oducts_id=1914
    and here:
    http://www.wurthusa.com/web/en/websi...lubricants.php
    I have most recently simply ordered and used GD-525 Moly Grease from:
    www.guarddogmolylubricants.com
    Paul....Want an opinion for the next time I lube a spline...probably this winter on a K75 or K11.
    Grainger has some spray moly...like a paint, that is a dry film lubricant. I used it on my R1150, but then I chickened out and used some Honda moly as well. Do you think this spray moly might stand a chance of working fairly well for the K bikes?
    http://www.grainger.com/Grainger/JET...KK2?Pid=search
    I don't mind experimenting a bit, since I could always dive into it again.
    Quote Originally Posted by JHGilbert View Post
    I don't think it does what we want by itself. A good spline lube lubricates, cushions, and prevents corrosion. A thin film of moly can be sprayed on as a dry film, or a moly powder can be brushed on, or even a high content moly paste can be brushed on, but all three methods would still lack cushioning and anti-corrosion additives.
    I wasn't thinking about the cushioning aspect of the grease, only its lubricating and dust catching properties. I suppose that if dry film lubricants were the solution, the factory would have implemented them long ago.
    Since moly molecules bond with steel a brushed on or sprayed on film is a good idea. With a moly grease we rely on the moly being enough in the grease to actually coat and bond the metal. I hava at times brushed on a 70% moly paste in a thin coating and then applied the heavy moly grease too.
    Sep 2006
    Diamondhead, MS
    Interesting to know that the Moly molecules actually bond with the steel instead of just riding on it.
    '03 R1150R, '03 F650GS, '97DR200SE,'78 Honda CT-90, '77Honda CT-90
