Results 1 to 8 of 8
Thread: i was wondering if anybody ever bored and stroked a 1000cc boxer engine...
    Registered User f14rio's Avatar
    mattituck new york
    ..to increase cubes. if so, with what results.
    thx,
    goo
    "Enemy fighters at 2 o'clock!...Roger, What should i do until then?"
    2010 r1200r, 2009 harley crossbones, 2008 triumph/sidecar, 1970 norton commando 750
    Administrator 20774's Avatar
    From what I've ready, there's very little meat in the cylinder walls (iron cylinders) to over bore the 1000cc engine. Once done, the walls may not be stable enough over time. Nikasil you can't do that because of the coating. Probably not worth boring and recoating.
    I think what people have tried is the 1050 Motoren-Israel kit.
    Apr 2006
    PSL, FL
    Quote Originally Posted by f14rio View Post
    thx,
    goo
    Isn't that what a Siebenrock 1070 kit is?
    May 2012
    VA
    Quote Originally Posted by les_garten View Post
    That is what I was thinking. Maybe some day I will get one of those Siebenrock 1000 cc kits for my R80/7, but I want better brakes before then.
    Stan
    AH# 13238
    Motoren-Israel has a 1070 kit:
    http://www.motoren-israel.com/produc...-Standard.html
    as does Seibenrock:
    http://www.siebenrock.com/en/product...c/1101110.html
    I seem to have remembered 1050...looks like it's bumped to 1070 now. Inflation!
    Apr 2006
    PSL, FL
    as does Seibenrock:
    1050 was only Bored, not stroked...
    Kind like stirred, but not shaken.
    Ahh...as I heard in the Bahamas one time... "I Be Strokin'"! Need the longer rod! Whoops...
    Now I get it...thanks...
    Apr 2006
    PSL, FL
    The things that steered me away from all the Siebenrock kits is that they:
    1) do not take stock pistons.
    2) You have to buy a piston and cylinder together as a set, can't just buy a piston. Kinda like VCRs, just throw aways.
    The 1000cc kit cannot use 1000cc BMW pistons(without machine work to the piston)
    Other than those issue, it looks like they make really good stuff.
