Results 1 to 9 of 9
Thread: '09 F8GS random shut off
    Just took a call from a friend, on the road in WY. his 2009 F800GS, ~18,000 miles shut off 3 times today. hoping that someone might have a clue as to what the malady is.
    as he described it: riding along, on a slight decelration (hiway off ramp, or a stop light in city, etc) at varying speeds and gears, the motor just shuts off. Waits a few seconds and it fires right back up. Only once did he turn the key off/on after the shut down, it started up right away. never a full tank, but never happened with reserve light on either.
    thoughts? (my first guesses are wonky s-stand or engine cut-off sw)
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    2007 F800S (mine) did that, fixed, did that, fixed, did that, fixed, and did that, fixed.
    Under Arizona law it was lemon, and NA bought it back.
    My bike shown here
    Jordan M, MOA #24434
    My Blog
    Registered User sddinnh's Avatar
    May 2009
    New Hampshire
    The 09's had a faulty charcoal canister connection that was fixed on recall. Has this bike had that mod? If not, it sounds exactly like the symptoms I had before the tubings was re-routed and fixed.
    Steve
    So many roads - so little time.
    2013 R1200GSW
    I think it is the idle actuators dropping back too low. Maybe a recalibration with a GS911. Maybe a vacuum hose problem.
    Quote Originally Posted by sddinnh View Post
    I believe that was an issue only under wet/rainy conditions, where one of the hoses allowed water to get in from down low, no? (happened to mine once in riding it home from purchase in D.C.). they have had nothing but dry.
    regardless, not sure if it was done, but bike is currently at a shop in ID, so they would have access to that info. they are leaning towards bad fuel as the issue (or so i am told via phone message).
    With all respect due, that is not a good sign. That translates from German into shoptalk into American English as we don't know, lets blame the crappy American gas. I've heard of this being said a number of times. Eventually changing the fuel injectors seems to solve the problem.
    If they mean it got one bad tank, lets drain it, clean it, and fill it that is one thing. If they mean US gas is bad then that's entirely another.
    Aug 2008
    North Carolina
    Bikerfish - yes the recall was to put a "Y" connection in the drain line from the canister with the other connection being a vent line run to high up on the bike.
    What was happening was that was getting sucked into the canister during rainy conditions (OR WATER CROSSINGS) and as a result engine vacuum ended up being applied to the fuel tank and eventually the fuel pump was unable to work against the vacuum built up. If the canister is the cause of the stall popping the lid on the fuel tank will result in an INrush of air to the tank (hold a piece of paper close to cap when you open it, sometimes INrush is hard to distinguish from OUTrush).
    With the vacuum relieved you could ride on for some miles .... before the condition would re-occur.
    Huge thread on the stalling issue here:
    http://www.advrider.com/forums/showt...9#post15923909
    Registered User bmwgsrider's Avatar
    Amarillo, TX
    I just had this issue and so far I believe it has been my side stand switch causing the issue. I have not had any problems yet.
    Bye bye 2006 F650 GS for a 2011 F650 GS.
    have not heard back from my friend, so i'm thinking things have gotten sorted out. expect their return in a few more days, will offer a status update once it's known.
    thanks for all the suggestions- they were passed on to him as "things to check".
