Results 1 to 3 of 3
Thread: 93 K1100LT Radio Remote ?
    I have 93 K1100LT and the radio remote quit. I've replaced it, the mount the radio slides into and checked wiring, the red led sometimes will come on but still doesn't work when it does. Please help, Thanks
    Motomark motomark's Avatar
    Jul 2007
    Clyde N.C.
    If you interupted the power supply to the radio at any time while you were replacing the remote you will have to reset the security code.Once code is reentered radio should operate normally.
    Good Luck
    1971 R75/5,1990 K75RT,1994 K75,1999 KLR
    Registered User kioolt's Avatar
    I don't know what your problem is with your remote but I can give you a little information that may help you decide. The remote on your bike is nothing complicated. It is simply several pushbuttons. The only electronic part in it is the red led. Everything else is just pushbuttons. I can't recall the exact wiring for one of these remotes but if you have an ohmmeter you should be able to tell if the switches are working.
    2004 R1150RT 171,200 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 406,800 BMW miles
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
