Results 1 to 15 of 22
Thread: K75S Maintenance
    Registered User detbmw's Avatar
    Feb 2005
    Deep East Texas
    K75S Maintenance
    I'm about to start a full service on my '88 K75S.
    I have a pair of Bridgestone - Battlax BT45V Sport Touring Tires on order. The Metzeler Lasertecs that came on it are both 5 & 1/2 years old.
    I also want to replace the valve stems. What size valve stems should I buy for this 1988 model bike that was built in July 1987?
    Rich
    2000 R1100RT, 1988 K75S
    East Texas BMW+ Motorcycle Club
    Texas National Picnic, Jacksonville TX, 3rd Saturday in May
    Quote Originally Posted by detbmw View Post
    BMW calls them 15mm which is the OD of the rubber.
    At the auto parts store get the smaller of the two sizes generally in stock. They are labeled as .453 inch which is 11.5mm. The .625 are way too big. These are hole sizes. Get them as short as you can: less wobble and much easier to put a hose on than long ones.
    Astatula, FL
    And buy an extra set to carry with you.
    Bob Weis
    '04 K12RS - Hannigan Hack
    Quote Originally Posted by Bobmws View Post
    Which is very easy since they often come as a package of four for your car.
    BMW uber alles! Zagando's Avatar
    Apr 2007
    Rockport, TX
    Thumbs up
    Congratulations on choosing the BT45s; man, you are going to love those tires!
    Btw, I run DynaBeads in both of mine and can also highly recommend them---smooth as silk.
    ---Jeff
    ex: K75S Berlina R100GS/PD , K100RS , R75/5 , R60/2
    Feb 2005
    Deep East Texas
    Quote Originally Posted by Zagando View Post
    I will order the DynaBeads, i have heard several people recommend them.
    Rich
    Jun 2008
    Canyon, TX.
    My first tire change on my K75 I put in metal valve stems. They look a lot better(bling?) and no more worries about a stem breaking.
    Registered User argent brick's Avatar
    Aug 2012
    Wine Country, Northern California
    anyone find the metal stems that have a 90 degree bend any easier to use?
    Registered User jwetering's Avatar
    Aug 2011
    north vancouver
    Hhmmm.
    I have the Bt45's on my bike and I'm finding they wear kind of fast. I think my fronts are cupping already after only abut 4 months of use.
    Maybe I'm riding 'em too hard?
    jasper
    north vancouver
    1990 K75S
    Astatula, FL
    Quote Originally Posted by jwetering View Post
    Hhmmm.
    How many miles and what tire pressure?
    Bob Weis
    Northern Front Range, CO
    what does that even mean?
    Ride Safe, Ride Lots
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    There is no such thing!
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2007
    Rockport, TX
    Quote Originally Posted by ARGENT BRICK View Post
    Easier to put air in but a bitch to install Dyna Beads with!
    ---Jeff
    Aug 2011
    north vancouver
    I run 33/36 and the mileage is 60,000 miles.
    I think I know where you're going with this, and I'm right behind you.
    I have already figured out that my headstock bearings are worn...more correctly that there's a notch on centre. This may be either causing the very mild wobble I feel directly, or it may be causing the tires to cup prematurely.
    My plan is to rebuild it this winter.
    jasper
    north vancouver
    1990 K75S
    Astatula, FL
    Well, I meant miles on that tire, but yes, worn bearings will contribute to the wear. Your tire pressures are about 4 lbs low on each end, more of a factor in the rapid wear.
    Bob Weis
