Results 1 to 15 of 38
Thread: embarrassed to say... Help me with center stand!
Hybrid View
    Registered User R1200RClassic's Avatar
    Jun 2012
    San Mateo, CA
    Ok, I'm a 210lb male, very able bodied, but for some reason it takes me 3-4 (sometimes more) tries to get my R1200R up on the stand! Why? what am I doing wrong? I swear I've seen 120 girls do this with less effort?
    anyone got a trick to this to make it easier?
    2016 K1600GTL - All Optons
    2012 R1200R - Classic / ESA II, ABS II, ASC, Heated Grips, Sports Windshield, Computer. - GONE
    2005 Honda Shadow 750 Spirit - GONE
    Jerk and stomp. I combine inertia of the bike and my body weight thrown backward followed by putting all my weight on the centerstand lever.
    Mansfield,MA
    It's sorta all in the wrist....and the geometry of arm length and inseam
    There is a good Best of Forum on the subject- hope it helps, that and a bit of practice. OM
    http://forums.bmwmoa.org/showthread.php?t=38314
    Mod Squad
    2009 F800GS 1994 TW200
    Left Coast Rider
    Put foot on centre stand. grab lift handle. Lift straight up. Done.
    Jul 2007
    THE BIG SKY
    Much, if not most, of the work is done by putting your weight on the centerstand with your foot. Think of yourself pushing the bike up, not lifting it up. Be the bike, Grasshopper.....
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    May 2008
    Racine, WI
    Occasionally I forget about the dynamics of getting my R1200GS up on the center stand and I have to give the rider's manual a quick check, it is all about "...Place full weight of body on center stand while pulling motorcycle toward rear."
    Once in awhile I'll try to pull it up instead of pulling it toward rear. Once I get that, it is a piece of cake.
    From the rider's manual...
    1. Switch off engine.
    2. Dismount and keep your left
    hand on left handlebar grip.
    3. With your right hand, take hold
    of the rear frame.
    4. Using your right foot, press
    center stand toward rear until
    feet rest on ground.
    5. Place full weight of body on
    toward rear.
    Dick
    R1200GS '08
    "Hey, where you goin'?" "Nowhere in particular." "Man, I wish I was you." "Well, Hang in there..."
    Jun 2012
    San Mateo, CA
    ah, it's the weight on center stand thing that I was missing!
    works much better now... thanks yall...
    sMiling Voni's Avatar
    Or, just say NO. Your bike doesn't have to go on the center stand. The side stand works just fine.
    Voni
    sMiling a Million on the side stand
    Aug 2004
    Walnut Creek, CA
    Quote Originally Posted by rjzinc View Post
    I have an older model (88 R100 RT), and I've found that pulling up AND to the rear is the easiest way to get the bike on the center stand. This is done while stepping on the center stand.
    Jeff in W.C.
    Ash Grove, MO
    Make sure it is in nuetral!
    Mike Davis
    1985 K100RT
    1998 R1100RT
    Kbiker BCKRider's Avatar
    Jan 2009
    B.C. Canada
    Bluejayrover (post #20) makes a good point; have the bike in gear when you take it off the center stand. I point the bars straight ahead, left hand on the grip, right hand on handle you use for putting the bike up on the center stand. Feel like I'm more balanced than with both hands on the grips. BUT you don't have a brake, which can be exciting if the ground slopes a bit downhill and you are NOT in gear! Then put down the side stand before you mount up in case a foot slips.
    Probably already mentioned in this thread, but DON'T use the center stand unless the ground is truly flat and hard. A little tilt to the right when the right center stand foot hits a soft spot and ... it's over.
    Talk to really experienced riders (after you have admitted a dumb mistake or two) and almost universally they cough up several of their own. Some time ago I wrote an article for the ON titled DON'T DROP THE BIKE which also appeared in the Forum. Check it out if this sort of thing interests you. Maybe you will discover a stupid mistake that you haven't made yet!
    Doug
    1992 K100RS
    Mar 2012
    Las Vegas
    If you continue to have difficulty despite all of the advice you have received, try this. Get a 1/2" thick piece of wood (something like a circular piece from Lowe's or Home Depot meant for making a Lazy Susan) and (in the privacy of your garage) ride the bike onto it so the front tire stops in the center of the piece of wood. Using the techniques described in other posts to your thread, the bike will virtually hop onto the center stand. After a few successful tries with the wood "turntable", you will have the technique and confidence down and won't require the wood any longer.
    mattituck new york
    here ya go
    Center stand warning
    Make sure you have clearance behind you when you put the bike on the centerstand.
    I can't say why I would know about that.
    Robb
