Results 1 to 5 of 5
Thread: Wheel to Drive Torque (2004K12GT)
    Joe T joetk75s's Avatar
    Apr 2004
    North Providence, RI 02904
    Smile Wheel to Drive Torque (2004K12GT)
    Short and sweet question from a novice mechanic.
    I took the wheel off my GT to have the tire replaced and when I looked at the Clymer manual about putting it back on it talked about torque wrench numbers. I put the bolts back on in the order recommended but don't have a torque wrench. All five went on without a hitch and everything looks just fine.
    Am I okay without the torque wrench?
    Curious Novice,
    JT
    Nibley, UT USA
    No, you need to torque those bolts correctly per the manual procedure. Bolts should be clean and dry. I usually hit mine with a stainless steel brush to make sure there's no scale on them. Also make sure the wheel and drive mounting surfaces are clean and dry. Insert the bolts and tighten in the approved pattern in two stages. Initial torque is 50nm (newton-meters) and final torque is 105nm.
    Guessing at the torque on those bolts can result in a wheel coming loose at speed, and you certainly don't want that! You can pick up a serviceable clicker-style torque wrench for $50 or less if you watch the sales at Sears or other vendors. If you're going to be doing much service work yourself you'll be wanting a torque wrench or two (3/8" drive and 1/4" drive) in your tool box.
    Best,
    GTRider
    DGerber
    1983 R80ST -- 1988 K100RS (r.i.p.) -- 1995 R1100RSL (gone, never forgotten) -- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    Themason 42906's Avatar
    Ridgecrest California
    It's 75 ft-lbs on early K bikes. What is the torque spec on these?
    Experience is what you get when you don't get what you want.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by Themason View Post
    Same
    Lee 2011 K1300S
    MOA # 30878
    Nibley, UT USA
    Here's a quick conversion reference:
    http://www.thetoolhut.com/Torque-Con...c-English.html
    Best,
    GTRider
    DGerber
