Results 1 to 8 of 8
Thread: The oldtimers is settin' in . . . . . .
    Aug 2008
    North Carolina Coast
    I took things apart in May before a major project and I have forgotten about a set of electrical contacts.
    On my 1993 R100RT there is a bright blue recepticle with five male contacts. There is room for six contacts but one is missing. This recepticle has no cover and is on the right side of the m/c. It is located behind the headlight and start relays. What plugs into this recepticle?
    Thanks,
    Campbell Tellman II
    Nov 2005
    Fairfax, VA
    Nothing -- I can't remember whether it should have a cover, but I recall that it is primarily there for Authority versions of the RT to power lights, etc.
    Mark Neblett
    Fairfax, VA
    #32806
    Aug 2008
    Memory Loss . . .
    Thanks for the input Mark.
    Campbell Tellman II
    Luddite Looney wecm31's Avatar
    Jun 2009
    Eganville, Ontario
    Campbell, do you have heated grips??
    I seem to recall when I bought my bike, I installed a factory kit
    to upgrade to heated grips. And that blue plug was waiting for
    me, just had to plug in the harness from the kit.
    Same answer as Mark, extra stuff you don't have...
    Gerald P
    The last thing I want to be is just like everyone else...
    1985 R80RT
    1969 Sport Fury Convertible
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by wecm31 View Post
    Maybe a different blue plug? My '94 RT's heated grips were connected elsewhere (BMW kit). The empty blue plug I'm referring to is back nearly to the end of the frame backbone.
    Mark Neblett
    Fairfax, VA
    #32806
    Registered User b25bsaboy's Avatar
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by CTellman View Post
    Thanks,
    Campbell Tellman II
    Your heading tells me you had a Brain Fart!
    Hope others can guide you in the right direction.....
    Rick MacPherson
    Success is Not a Destination, But a Journey.
    Accredited Motorcycle Appraiser
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    MonoRT MonoRT's Avatar
    Jun 2011
    Huntington Beach, CA
    My 1985 R80RT has that same connector block. It had a plastic cover which went somewhere without me a few years back. When the bike was new, someone told me that it was for a factory diagnostic device, but I'm inclined to doubt that. On the other hand, I've just been too lazy to trace the wires to see if the connector appears to have been designed to power something or to diagnose something.
    At any rate, I've never used it or seen it used for anything. I would not worry about it.
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by MonoRT View Post
    That rings a bell -- I remember at gray, flat-topped cover for the blue plug.
    I did -- the schematic I reviewed had references to Authority equipment.
    I used the 12V terminal in the plug to power some long-forgotton piece of electronics (a helmet speaker for listening to mp3's from a GPS, IIRC) -- a convenient source of ignition-switched 12V power.
    Given that at least one of the terminals is "live" when the ignition is on, the "prudent" thing to do would be to provides some sort of cover/plug/weather protection. That said, given where the plug is, it would take quite a monsoon, or the routing of thinly-insulated wires directly over the blue plug for any real problem to ever occur. Probably the easiest thing to do is wrap electrician's tape around it, and then forget it.
    Mark Neblett
    Fairfax, VA
    #32806
