Results 1 to 4 of 4
Thread: clutch help
    Question clutch help
    I have a clutch with the following part #121211251803. I have been trying to find the model to which this will fit. I have tried the parts fiches with no success. Does anyone have a solution or bike model?
    Thanks,
    Gary
    Pismo Beach, CA
    Hi Gary, welcome aboard. The part number you gave, 121211251803, does not conform to BMW's 11-digit part numbering system (it has two too many numbers).
    21 21 1 251 801, is the pressure plate for the R100T (assuming from your username that you have an R100T).
    Here's the R100T parts page from MAXBMW > http://www.maxbmwmotorcycles.com/fic...3&rnd=08102012
    You can use this handy part number identifier found On MAXBMW's website. I tried manipulating the number that you gave, but no combination came up as a legit p/n.
    See > http://www.maxbmwmotorcycles.com/fiche/PartsSearch.aspx
    What particular part of the clutch are you referring to?
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Thanks Lew,
    Sorry it is a clutch plate.
    I have tried MAX with no result. Upon further scrutiny I found some other numbers; 09 1 884 278 003 or 08 1864 278 003. I did try these numbers as well but they came up 'no picture'. The number I gave you was on a tag attached to the plate.
    Gary
    Administrator 20774's Avatar
    Gary -
    Those numbers are also not valid parts numbers. If you find something that is stamped onto a part, more than likely it is not a part number, just some kind of internal tracking number.
    A clutch plate for a '81 R100RT (you didn't actually say what) is 21211451512:
    http://www.realoem.com/bmw/showparts...67&hg=21&fg=21
