Results 1 to 4 of 4
Thread: greasing airhead swingarm bearings
    Tom Durrant
    Kincardine Ontario Canada
    I got frustrated and haven't greased them nearly enough. Today, I removed the pins, cleaned them, drilled an 11/32" hole just down to the hex. I was able to partially thread the hole with a 1/8" tapered pipe tap (standard) I had to grind the end of the tap off a little to get as many threads in as I could. Now I can screw a standard grease fitting enough to hold it. I put a grease gun on and forced some grease in. Of course the fitting gets removed and the cover replaced. Next time, I'll pick a bit of the grubby grease in the hole out and I'll be able to pump some fresh grease in.
    Superkraut typ181r90's Avatar
    Sep 2009
    NJ
    I know you just went through all that work, but this works wonders:
    http://www.ebay.com/itm/Conical-Shap...item27ca257fc6
    Works on the swingarm bearings and is small enough at the tip to work on the rear brake pedal grease fitting as well, even got it to work on standard zerk fittings (like on a /6 clutch actuator arm). Took a little while to receive it from China, but the shipping was free and it works great for me
    // 1975 BMW R90/6 (cafe'd) // 1957 BMW R60 (in pieces) // 1967 Aermacchi/H-D Sprint 250 SS (custom special) // 1973 VW Type 181 Custom SOLD )
    Registered User donbmw's Avatar
    Feb 2004
    Monroe La.
    Quote Originally Posted by Typ181R90 View Post
    Any auto parts house will have tip like this.
    Don
    1975 R90/6, 1980 and 1982 R65, !959 TR3A Triumph Car
    Registered User Rod Sheridan's Avatar
    Oct 2005
    Toronto Ontario
    Quote Originally Posted by tomdurrant View Post
    Sounds like a lot of work modifying something that already has a grease hole in it.
    Why didn't you just spend $5 on the correct tip for your grease gun?
    Regards, Rod.
    Work is the curse of the riding class
