Page 14 of 20 FirstFirst ... 4 12 13 14 15 16 ... LastLast
Results 196 to 210 of 286
Thread: It's BMW Scooter Time!
  1. #196
    Nov 2012
    Quote Originally Posted by Gilly View Post
    Or alternatively use the top case????
    I would, if only BMW would deliver the darned thing!
  2. #197
    Jul 2007
    Evansville, WI
    OH you said you got that, I guess you want the color panels before you put it on?
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
  3. #198
    Nov 2012
    No rack to mount it to yet either unfortunately.
  4. #199
    On The Road Again
    California
    Net
    Jim,
    Took the under seat liner out and worked the problem through. Lots of extra space for small items behind the liner. Pics show the backside of liner with velcro toggles pushed through a cut in the liner, the other give one a view of the bottom frame member that the velcro is attached to.
  5. #200
    On The Road Again
    California
    Net
    Under the liner.
  6. #201
    Nov 2012
    Glad to see it! How was the liner attached - bolted on, or ...? (Didn't look to see...)
  7. #202
    Jul 2007
    Evansville, WI
    WOW really looks like a lot of space between the frame and tupperware, looks like wasted space BMW could have used to increase storage capacity, good spot if someone wanted to have a nice tool kit for example.
    13 C650GT
    MOA 44606
  8. #203
    Nov 2012
    Those top frame bars are inside the storage area, not outside - I could be wrong, but I don't think there's as much free space there as you might be thinking...
  9. #204
    On The Road Again
    California
    The liner is not fastened, easy to remove, with a little care.
  10. #205
    Nov 2012
    Quote Originally Posted by 30300 View Post
    So it's resting on the frame rails?
  11. #206
    Jul 2007
    Evansville, WI
    Quote Originally Posted by JimInSF View Post
    I thought the frame was hidden by the liner.
    I do agree it might not be that much space, hard to tell by just a picture, "1D" instead of "3D"
    13 C650GT
    MOA 44606
  12. #207
    On The Road Again
    California
    The majority is resting on the plastic that forms the top of the fender. You can have a peek at the sides, between the liner and the side of the body by just pulling the liner inward just forward of the upper frame rail that is visible.
    I have put a tire repair and pump on one side and jumper cables on the other, all between the liner and the body. On the right side there is an adjustment for the seat release.
  13. #208
    Jeff Wilson life member 43362's Avatar
    Jun 2012
    Richmond Hill Ontario Canada
    Wind deflectors
    I read on another website that the wind deflectors for your hands at $181 were not worth the money. I had no intentions on that purchase. This is for your info.
    Jeff
    A bad day on the C650 GT scooter is better than the best day at work
  14. #209
    Jul 2007
    Evansville, WI
    Is that the panels on the fairing that sort of sweep upwards and flare out to deflect the wind?
    $198 at A&S:
    http://www.ascycles.com/detail.aspx?ID=125652
    13 C650GT
    MOA 44606
  15. #210
    Jun 2012
    $198 at A&S:
    Sorry you are correct (i was just quoting the other post)
    Jeff
