Results 16 to 28 of 28
Thread: New [to me] K1200LT '02
    Supporting our Vets jers99lt's Avatar
    Jun 2010
    Warrenville, IL
    Quote Originally Posted by 71243 View Post
    Going to order a set of Continental tires
    Ron
    Hi Ron,
    There's only 3 maufacturers that provide the required/spec'd tire for an LT. Metzler, Bridgestone and Avon.
    HTH,
    Jer
    Jerry Palma
    99 K1200LTI Champagne 'Oh, Kay' (dropped: 4); 85 R80RT 'Lady in Red'; 08 535xi Space Gray metallic; 09 328i Silver Convertable
    I love these bikes regardless of what I've needed to fix on them. I'll: Just Ride 'em!
    Quote Originally Posted by jers99lt View Post
    Hi Ron,
    HTH,
    Jer
    The correct size is not the only important spec.(as Jer points out). Load capacity is very important with the LT as is the speed rating.
    Is there supposed to be a try or battery cover, or ?? under the seat?
    Nov 2005
    Fairfax, VA
    Nope.
    Mark Neblett
    Fairfax, VA
    #32806
    Hope you guys don't mind all these questions?
    Anyone ever removed those "knee-pads" on the side?...wondering what it would look like without them? On this one they are dry cracked , might just remove them and paint under them if need be. I don't have it here yet, probably Mon,or Tue. I have no way of going to get it, and then get back,etc..so my friend is going to deliver it then.
    Ron
    Nov 2005
    Fairfax, VA
    Ron
    No problems with the Qs -- that's why many of us are here.
    It's been a while, but my memory is that the pads are held in place via screws/holes on the back side of the panel, and the surface under the pads is not smooth. I'd be more inclined to pick up used replacements from someplace like www.beemerboneyard.com, or taking the pads to a local upholstry shop to be recovered.
    Mark Neblett
    Fairfax, VA
    #32806
    Registered User johnbaker15's Avatar
    Sep 2011
    Chelmsford, Mass
    So now, I start looking for seat repair / replace options . Going to order a set of Continental tires,....winter's coming ....plenty of time to get it together.
    I have my Roadster to ride.
    Ron
    Continental does NOT make tires for this bike, Avon, Metzler, Bridgestone and the only tires rated for the bikes weight. You HAVE to get the reinforced rear tire.
    No kidding about this.
    BMW 2005 K1200LT
    Suzuki 1979 GS1000E
    May 2006
    Northern New Jersey
    +3 on the tire warning/advice.
    I once did my own research on buying a Dunlop, which was not a listed tire for my CLC. It was listed for a Harley dresser, but all the ratings matched up to the CLC also. The parts dept manager at my H-D/BMW dealership told me they would not even sell me the tire since I had told them of my plans to use it on the BMW. I was not insulted, I respected them for telling me that. SO, from that I got that the tire manufacturer's recommendations are to be taken seriously.
    Registered User E.L. Buff's Avatar
    Nov 2009
    Elmer New Jersey
    you can find parts on ebay my first choice is beemerboneyard going there
    Friday to get a new frame for my 03 K1200LT .
    Be careful on Ebay some parts are more then new ones so look up
    parts and prices first I use Max BMW for new parts .
    Once you ride a LT with all the fixings you will not want to be without them.
    I saw somewhere there is a rack or cover to finish the look with out the trunk.
    Ernie
    Nov 2009
    Elmer New Jersey
    oh ya the tires Metzler ME880 is all I ever use on mine and my father inlaw
    uses them to over 100000 miles on his 99Lt
    Ernie
  11. #26
    Quote Originally Posted by E.L. Buff View Post
    Ernie
    I have to ask, why do you need a new frame?
  12. #27
    Nov 2009
    Elmer New Jersey
    Long story
    Salvage bike all fixed and runs great . I got it from Canada with a PA title.
    New Jersey will not register it because it went to Canada and back.
    So got new frame with clear N J title Now I have a tag and all is well.
    Until this winter when I swap frames , I had it all apart before so no big deal
    Need new shocks anyway and install a com system with CB.
    And no you can not take knee pads off side panel not finished behind them .
    Ernie
  13. #28
    Long story
    Ernie
    Sorry bout being so nosy, I was just concerned that the frame was another problem area..
    Actually, the panel behind the knee pads, is finished. I looked. But the holes are there for the knee panel screws. So my 'sorta-plan' now is to fill in the holes, and re-finish that area [of] the panel, and paint that the second color, which is going to be Ferro blue metallic. In sort of a Nike Swoosh...still thinking things over.
