Results 1 to 8 of 8
Thread: 2000 R1100R died while riding and wont start
    I was out for a labor day ride made it about 45 miles from home got off the highway to enjoy back roads cruising and the bike stalled while riding along in 3rd at about 30-35mph quickly pulled the clutch and coasted , I then downshifted into 2nd and popped the clutch and she fired back up and went for another2miles or less and just died. It turns over fine and the kickstand kill switch seems to work (i can hear the pump prime when retracted )I coasted onto a side street and nothing, pulled a plug To see if I flooded it while trying to turn it over and it was dry, checked to see if there was a spark and nothing. I did feel a burp about a week ago while riding just motoring along at about 4500 rpm and she just seemed to quit momentarily, then just resumed riding?? This time she wont start no spark and apparently no gas. I do have fuel in the tank so I'm like what gives here? Thinking ignition module or some sort of short. Had to go get the girl in my pickup made for a very unhappy labor day. Anybody got any ideas??
    May 2012
    Escondido
    HES?
    How was the weather, really hot, or really wet?
    Have you ever replaced the Hall Effect Sensor?
    2000 R1100RT-P
    He's
    Weather was perfect 75 and sunny and no I have never replaced the hall effect sensor.
    South Carolina
    No spark and no gas sounds like the HES...
    AKA SNAPGADGET
    Mar 2007
    15 M. E. Tampa
    dead
    "..No spark and no gas sounds like the HES.." Yes, usually, but HES problems frequently still have fuel and spark...they just come at the wrong time. The HES can sometimes be diagnosed by watching the tach while trying to start the bike. If the tach jumps around, then definitely the HES is bad.
    Check your fuses also, but it will probably be the HES.
    Registered User 70783's Avatar
    Florissant, MO
    The same thing happened to me last year on Memorial Day. Replaced the HES(Hall Effect Sensor) and all has been well since. It is a fairly straight forward DYI project, but the part is pricey.
    Good Luck!
    Steve Bechtel
    '99 R1100RS
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Bosch HES
    Euromotoelectrics - updated wire type -approx. $210
    Ufda happens..........
    Thanks guys
    Your the best after asking about possible issues I did in fact settle on this little bugger and Viola it worked I found some very informative postings on different sites and was able to pull it off without a hitch! Thanks to all!
