Results 1 to 6 of 6
Thread: Inflating the sleeping pad...
    Registered User dadayama's Avatar
    Sep 2009
    Oklahoma City
    So i just bought a new Therm-a-rest Neoair sleeping pad, which packs up to a tiny little package compared to my old self inflating Therm-a-rest.
    But the new one has to be inflated by mouth, which takes few minutes, but not bad. I had an idea, and it worked and i think a person could use this for other applications as well.
    I have a little tire air-compressor made just for motorcycles, so I went and bought a tire valve stem, the big rubber butt end works like lips. Hook up to your tire pump and then inflate away...
    Hopefully that makes sense...
    Ich Fahre Nicht Zu Schnell, Ich Fliege Nur Niedrig
    Oklahoma Adventure Trail
    Nov 2005
    Lancaster County, PA
    Great idea. How long did it take?
    Sep 2009
    Oklahoma City
    Quote Originally Posted by john1691 View Post
    faster then blowing up by mouth that is for sure...
    My old Therm-a-rest is one of those self inflating... so i was a bit spoiled... this new one packs down small... i mean really small... so i think it will be worth the effort... we'll find out later this month...
    Registered User ezec's Avatar
    Aug 2011
    Arkansas
    excellent tip
    2010 R1200RT
    GO HOGS!
    Just north of Seattle, WA
    You're not supposed to blow into Therm-A-Rest pads
    Your breath contains moisture, and that moisture will mildew inside your sleeping pad.
    Therm-A-Rest pads - like sleeping bags - should never be stored rolled up/folded up/stuffed in a stuff sack.
    Therm-A-Rest pads should be stored unrolled/unfolded, with the valves open. A great place to store them is under a bed. If the foam is only compressed when the pad is transported, then it won't "memorize" being compressed, and it will self-inflate on it's own as soon as the valve is opened.
    There's nothing wrong with a couple of breaths into the valve if you like a firmer sleep pad, but inflating the entire thing with your breath means the pad is no longer a "self-inflator", and that it's likely infested with mildew and mold.
    If you want to put your lips around a straw connected to a container full of mildew and mold, be my guest
    Seattle, WA
    2012 R1200GSA
    2002 R1150RT-P
    1992 K75S sold
    May 2008
    Racine, WI
    Actually, Therm-a-rest has a different view of inflating their mattresses. http://cascadedesigns.com/therm-a-rest/FAQ
    What‘«÷s the best way to inflate my NeoAir‘šů mattress?
    Unroll your NeoAir mattress and open the valve. Blow air into the first section of the mattress and close the valve. Push the air from the inflated section into the bottom, non-inflated section of the mattress with the valve still closed. Open the valve and continue inflation. A regular length mattress takes an average of 20 strong breaths to inflate fully. Once inflated, you can personalize firmness by lying on the mattress with the valve near your head. Simply reach up and open the valve slightly to create your ideal level of support.
    Will moisture build-up and ruin my mattress if I blow into it?
    No. We have spent decades refining our coatings and fabrics to withstand such things and this assurance of lasting quality separates Therm-a-Rest mattresses from every other competitor. However, minimizing moisture is always a good idea. Always allow self-inflating mattresses to inflate on their own as much as possible, then just top them off with a few breaths at the end for added firmness. We also recommend storing your mattress unrolled and with the valve open. This keeps the foam core at maximum loft and allows any moisture build-up to evaporate slowly.
    Dick
    R1200GS '08
    "Hey, where you goin'?" "Nowhere in particular." "Man, I wish I was you." "Well, Hang in there..."
