Results 1 to 14 of 14
Thread: How to dissolve old glue from tank roundel(s) and knee pads
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    Got the roundels and knee pads off but goof off and goo gone don't even seem to soften this black substance from hell. . Any advice?? (74 R90/6)
    '92 R100GS '81 R100/t brittrunyon's Avatar
    Sep 2009
    Ojo Caliente, New Mexico
    Denatured Alcohol....?
    1992 R100 GS, 2007 F 650 GS
    Big Bend Ride video at http://brittrunyon.com/
    More riding videos @ http://vimeo.com/user2721333/videos
    Mar 2008
    DeLand Florida
    Tar and bug remover.
    May 2012
    Southeast Arizona....where we ride year round.
    WD40
    Works great and won't harm the paint.
    Mar 2012
    Lexington, IL
    I'll have to try some of those. Quit when sandblaster started looking like a smart move.
    Registered User PittsDriver's Avatar
    Feb 2012
    I'd be careful with the chemicals. Try a steamy hot wet towel to soften it up. Then if it's still resistant, Varsol or some variation of mineral spirits. I've also found that a hair dryer works pretty well to soften up the glue.
    Jun 2012
    Olympia, WA
    I removed mine off the tank and cowl using a heat gun (like a super hot hair dryer) and a tiny screwdriver to pry.
    Just don't use more heat than necessary.
    Jun 2007
    Portsmouth, NH
    3M makes an adhesive removed intended for just such applications.
    Eastern KY
    If you need to dissolve a substance then the item involved needs more specific identification. You need to say if it is a painted roundel or a porcelain & what metal is involved & then others can avoid wild guesses as to what will safely dissolve the adhesive. Often times plain old carefully applied elbow grease works best.
    Dec 2010
    I've tried a few glue/goo desolvers and {IMO} WD-40 and a few clean towels are still the best.
    Albuquerque, NM
    Quote Originally Posted by Anyname View Post
    Indeed they do and it's what I'd recommend as well. At body shop supply stores.
    Kent Christensen
    21482
    Mar 2012
    Lexington, IL
    Well the roundel adhesive is completely gone now with a little soaking, but I've found nothing to soften the remnants where the knee pads were. Good news is that the painter says he has solvents for it and is happy I've done as much as I have. (so I'm off the hook. )
    Layton layton's Avatar
    Mar 2005
    Ft. Smith Ar
    Hand sanitizer.....Takes off just about anything...
    Registered User argent brick's Avatar
    Aug 2012
    Wine Country, Northern California
    Ronsonal lighter fluid should work well for the roundels. Try Naphtha also.
    I am planning to remove the knee pads off of my K75. Please let us know what works for that.
